Results 11 to 14 of 14
Tsikot Member Rank 3
- Mar 2004
- 2,053
October 19th, 2015 05:26 PM #11Those wiper streaks can only be removed using a water mark remover (Elevo, Glass Science's Glass Scrub, and Microtex Glaz Stainz), and a LOT of elbow grease.
From your original post, you mentioned that you've already used different kinds of cleaning products. If by chance you already have one of the products mentioned above, here's what you should do:
- Work on a small section of your windshield --- mga 8inch x 8inch. As in todo punas nung product. When you think you've already cleaned it completely, buhusan mo ng tubig yung windshield mo. The water should SHEET over the area you've cleaned. Dapat uniform yung sheeting. Kung biglang may dry area na nag form sa gitna nung sheet, then that dry area needs to be treated again. Repeat your process on that area until the sheeting becomes consistent.
- When you think the sheeting is already consistent, try mo paandarin yung windshield wiper mo doon sa area na nilinis mo. Dapat wala na yung streaking.
- Once you are satisfied, that's when you should move to the next area to clean.
- Once you've finished working on the entire windshield, that's when you apply the RainX product.
- Also, if you haven't done so, you may want to replace your wiper blades after you finish cleaning your windshield.
October 19th, 2015 05:57 PM #12
ooops, mali basa ko ng problem mo kasi di ko see yung picture sa tab. ngayon ko lang na-open sa desk top so now ko lang nakita yung picture.
looks like madumi windshield mo sir. try mo palinis, or pwede din diy. kung diy e meron ako nabili sa wilcon na windshield glass polish. parang rubbing compound pero para sa windshield. yung kasi sorento ko e nag ganyan last year so ni-polish ko yung windshield. i spent a day doing it. after nun i applied rainaway water repellant. ok na siya ngayon hindi na nagkaganyan. or let the pros do it. sa detailing shops (yung hindi tabi-tabi) they can do that for you.
- Jul 2009
- 153
October 20th, 2015 03:09 PM #14
How old are the wiper blades? If it's more than 2 years, replace them. The difference in performance will be night and day.
some of my friends just collect... impossible for them to ride it. noticed din with my wife na...
Mitsubishi Xforce
