Results 1 to 10 of 14
October 18th, 2015 03:46 AM #1
Hi Guys! I recently bought a 2nd hand car, Honda Civic 2000. So far, OK naman lahat, but recently nung umulan napansin ko everytime nadadaanan ng wiper yung windshield ko may moist na stain. I already tried na punasan, bumili na din ako ng kung anu-anong panlinis ng salamin pero hindi parin talaga nawawala. Please help me po sa mga nakakaalam. Salamat!
October 18th, 2015 09:10 AM #2
I also have this problem. My driver and passenger windows nag momoist/haze din. Napaka delikado. Hope someone could help. [emoji17]
- Aug 2013
- 805
October 18th, 2015 09:26 AM #3Punasan ng shaving cream, tapos punasan ng tuyong basahan hanggang luminaw yung glass.
Sent from my SM-T705 using Tapatalk
October 18th, 2015 09:48 AM #4
meron anti-mist/anti-fog coating for that problem. rain x anti-fog works best in my experience, kaso lang mahirap hanapin. try other brands din like rainaway.
https://www.rainx.com/product/glass-...ainx-anti-fog/
October 18th, 2015 09:48 AM #5
October 18th, 2015 09:49 AM #6
A few possible causes and solution:
1. A/C is set too cold or the vents are set to window de-fog mode - Adjust the A/C thermostat for comfort cooling and/or redirect the vents to the passengers.
2. Worn-out wiper blades - Even if they look perfectly good, microscopic cracks or deformities on the edge of the wiper blades will cause smearing. Replace them regularly. 1.5-3 years is the typical wiper lifespan, depending on how often it is exposed to the sun. Use genuine and reputable brands like Bosch.
October 18th, 2015 11:14 AM #7
another possible solution is to turn off the car’s recirculation mode so the temp & moisture inside the car begin to equalize with outside temp.
October 18th, 2015 11:14 AM #8
- Jul 2013
- 2,450
October 18th, 2015 11:31 AM #9You might also want to have the exterior part of the windshield cleaned of water stains.
October 18th, 2015 08:39 PM #10
pwede na siguro presyo kay lazada kung mahirap hanapin.
Rain X Original Improved Rain Visibility Windshield 207mL | Lazada PH
For the Toyota products its likely to be the case for most of their products per the service...
Wheel Alignment
