Results 21 to 30 of 58
February 12th, 2006 07:14 AM #21
Yun corolla namin nag stop yun odo when we had the clutch disc replaced. Don't know what happened, may na disconnect siguro.
February 12th, 2006 07:23 AM #22
usually yung cable daw ng speedo is connected to the tranny. when they replaced the clutch disc, may nakalimutan sila malamang na ibalik ikabit.
February 12th, 2006 07:32 AM #23
i was at buendia auto center one time. i asked about the mileage of an exsior in display. sabi nung mama, "88." pagtingin ko sa odo, nakita ko "68." sorry if this post is conclusive. hindi ko naman sigurado. pero marami na rin ako nabasa about tampered used cars, both digital and analog odo. mayroon din dito sa better living, ung ayala shuttle driver na naka-barong, pansin ko mukhang inistop niya ang speedometer niya. sa mga may balak pa mandaya ng odo, baka karmahin kayo sana! hahaha.
February 12th, 2006 07:36 AM #24
eek. sa levitown ka, onewaytrip? la lang. hehehehe.
anyway, back on topic, true, masama nga mandaya ng odo kung ibebenta mo rin.
February 12th, 2006 07:58 AM #25
Kung digital, the only way that I KNOW and had a first hand experience is by replacing the entire odometer.
Here's how it is typically done, I've posted this a while ago.
1. buy a spare odometer
2. use the spare odometer when making long trips or whenever you want to preserve the meter.
3. install the orig odometer and have your car serviced to CASA. CASA record will reflect the orig odometer which is not regularly used
4. After CASA service, drive for 3,000 km and put the spare odometer
5. keep driving but "log" the mileage so you know when to properly change the oil
6. Have another shop (NON-CASA) or DIY oil change with your spare odometer
7. after three months, go back to CASA with the orig odometer
viola, low mileage car and then sell it. Hence, the logbook you found.
kahit JDM pa ang spare odometer, it doesnt matter dahil gagamitin mo lang naman yon to rack up the mileage. Alternate the non-CASA to CASA service para hindi halata ng CASA na ambilis mo bumalik although one month pa lang since your last oil change. Or you can make an excuse that you like to have the oil changed every 1,000km kahit na naka 5,000km ka na for a month.
February 12th, 2006 08:05 AM #27Originally Posted by nugundam93
Originally Posted by umzzzzzLast edited by Karding; February 12th, 2006 at 08:08 AM.
February 12th, 2006 08:06 AM #28Originally Posted by Karding
Put it this way: given the right equipment and knowledge, a digital odo is EASIER to tamper with than an analog odo (de-pindot lang imbis na de-ikot). I like the mechanical odos, they're cute heheheh.
February 12th, 2006 08:12 AM #29May pinakita dati sa Auto Motor&Sport (sa Channel 25) na nagmomodify ng odo. Yung equipment niya de-pindot lang napapalitan yung reading!
using a non-CASA will ensure that your orig mileage is not recorded on their networked records.
high idle RPM at engine start
