Results 1 to 10 of 16
- Nov 2002
- 162
November 27th, 2002 09:36 PM #1bakit pag nilolock ko yung door ng accord e pagkatapos nya maglock e parang yung mechanism na naglolock and unlock dirediretso pa din ang andar. siguro mga ten times mo pa madidinig na parang naglolock and unlock sya.
ganon din pag nalulubak. ano ba sira nito?
November 28th, 2002 03:42 AM #2
The same thing happened with my Strada noong bago pa siya. I had it checked and the culprit is the alarm system (Code Alarm). Pa-check mo dude at baka same din ang problem. They just adjusted my alarm then voila ok na. Goodluck. :D
- Nov 2002
- 162
November 28th, 2002 12:29 PM #3Where did you have it checked? sa casa ba? Ayaw ko kasi dalhin sa casa e. May shop ka bang alam?
November 28th, 2002 04:40 PM #4
boybitz: ano ba model ng accord mo? same prob with my 97 accord.
i had it checked noong nagpakabit ako ng aftermarket car alarm and the problem was the actuator ng drivers lock, sira na, it couldnt "sense" na all the door were locked na. had to replace it daw pero pinagawa ko lang is i had the actuator "control" ng drivers side disconnected so the only way i could central lock was by using either the lock mechanism ng driver(yung lock/unlock button) or by using the alarm pager. if i lock/unlock by using the lock on the drivers door, all it does it lock that single door. it worked for me. i had it done sa CAtS-butas bulsa ko hehehehe :shock:
November 28th, 2002 11:19 PM #5
sa 96 accord namin nagluko-loko rin yung power locks, twice na ata...
November 29th, 2002 04:35 AM #6
boybitz,
Since under warranty pa Strada ko I tried bringing it sa Casa (Union Motors). Since third party pala installer ng alarm nila I was directed to go to a shop: WinterPine Marketing along G. Araneta Ave., Q.C. There in-adjust ng tech nila iyong OEM Code Alarm. After that it's 1 1/2 years na and problem free. You can visit the shop. They may be able to help. You may also try other shops in Banawe who also install your brand of alarm. Taga sa casa if out of warranty. Goodluck. :D
- Nov 2002
- 162
November 29th, 2002 01:00 PM #7thanks sa replies.
97 accord din. d kaya factory defect to ng accord. Nakakainis kasi yung tunog nya. Tapos pag nalulubak minsan naglolock-unlock din sya. pero di naman talaga sya nag-uunlock.
I'll try sa winterpine, baka kaya din nila.
- Nov 2002
- 162
December 5th, 2002 07:38 PM #8Galing ako ng winterpine, d daw nila kaya kasi orig pa yung power locks ko. Meron pa ba kayong alam na marunong mag-ayos? Last choice na talaga yung casa.
- Jun 2004
- 4
June 9th, 2004 09:47 AM #9good am,
help mga people, nag auto unlock ang kotse ko ( esi 95 ) , pag ni lock ko sya sa driver side after mga 45 seconds or more, mag unlock na naman lahat ng pinto, may relation ba to sa alarm? help naman po, nakapark kotse ko bukas, pero may alarm
thanks
June 9th, 2004 10:05 AM #10
Pre,
Baka me sira ang actuator ng auto mo. Parang ganyan din auto ko dati eh. Pag ini lock ko eh , nag u-unlock ng kusa.
does it mean no huge differences between ceramic vs crystalline ?
