Results 1 to 16 of 16
    bakit pag nilolock ko yung door ng accord e pagkatapos nya maglock e parang yung mechanism na naglolock and unlock dirediretso pa din ang andar. siguro mga ten times mo pa madidinig na parang naglolock and unlock sya.
    ganon din pag nalulubak. ano ba sira nito?
    The same thing happened with my Strada noong bago pa siya. I had it checked and the culprit is the alarm system (Code Alarm). Pa-check mo dude at baka same din ang problem. They just adjusted my alarm then voila ok na. Goodluck. :D
    Where did you have it checked? sa casa ba? Ayaw ko kasi dalhin sa casa e. May shop ka bang alam?
    boybitz: ano ba model ng accord mo? same prob with my 97 accord.
    i had it checked noong nagpakabit ako ng aftermarket car alarm and the problem was the actuator ng drivers lock, sira na, it couldnt "sense" na all the door were locked na. had to replace it daw pero pinagawa ko lang is i had the actuator "control" ng drivers side disconnected so the only way i could central lock was by using either the lock mechanism ng driver(yung lock/unlock button) or by using the alarm pager. if i lock/unlock by using the lock on the drivers door, all it does it lock that single door. it worked for me. i had it done sa CAtS-butas bulsa ko hehehehe :shock:
    sa 96 accord namin nagluko-loko rin yung power locks, twice na ata...
    boybitz,
    Since under warranty pa Strada ko I tried bringing it sa Casa (Union Motors). Since third party pala installer ng alarm nila I was directed to go to a shop: WinterPine Marketing along G. Araneta Ave., Q.C. There in-adjust ng tech nila iyong OEM Code Alarm. After that it's 1 1/2 years na and problem free. You can visit the shop. They may be able to help. You may also try other shops in Banawe who also install your brand of alarm. Taga sa casa if out of warranty. Goodluck. :D
    thanks sa replies.
    97 accord din. d kaya factory defect to ng accord. Nakakainis kasi yung tunog nya. Tapos pag nalulubak minsan naglolock-unlock din sya. pero di naman talaga sya nag-uunlock.
    I'll try sa winterpine, baka kaya din nila.
    Galing ako ng winterpine, d daw nila kaya kasi orig pa yung power locks ko. Meron pa ba kayong alam na marunong mag-ayos? Last choice na talaga yung casa.
    Jun 2004
    good am,
    help mga people, nag auto unlock ang kotse ko ( esi 95 ) , pag ni lock ko sya sa driver side after mga 45 seconds or more, mag unlock na naman lahat ng pinto, may relation ba to sa alarm? help naman po, nakapark kotse ko bukas, pero may alarm
    thanks
    Pre,
    Baka me sira ang actuator ng auto mo. Parang ganyan din auto ko dati eh. Pag ini lock ko eh , nag u-unlock ng kusa.
    Jun 2004
    salamat sa reply pre, ganun.. tsk tsk tsk.. anong cause ng pagkasira? bigla lang, kasi sunday ok pa yun eh.. saan po pwede magpagawa/magpapalit ng actuator? makati/pasig area po ako, at mga magkano po ang aabutin na gastos ?
    thanks uli
    Jan 2004
    sir regarding sa actuator kung yan nga ang sira mura lang yan. mga 900 isang set sa concorde or sa may sm north edsa 2nd level malapit sa cinema. i forgot the name nung store e.
    yep, or i guess, related sa alarm yan.
    pa -check mo rin sa banawe kung may time ka.
    Jun 2004
    thanks bro, sige check ko mamya, meron din kaya sa evangista?
  14. #14
    most probably sa alarm but possible din sa actuator or sa central locking unit
    Jun 2004
    Kung malapit ka sa Makati, may nagagawa ng actuator sa may gilid ng mga car accessories sa Yakal street. Presyo niya sa akin dati mg 250 per actuator. Wala siyang puwesto nagsa-sideline lang pero he is an expert dahil sa kanya ko rin pinapalit iyung window runner channel sa driver side dahil punit na. 200 ang labor niya.
    Jun 2004
    thanks guys, napaayos ko na sa banawe, yung alarm ang may problema... ni re-program uli
Merged: door locks
