Results 1 to 11 of 11
  1. Osiris Guest
    Just had a change oil service for my MAZDA familia. I changed my fuel filter. But I noticed na 626 naka mark sa filter and the shop where I bought it told me its the same for the familia. Is it true? Napansin ko a3 days after na parang palyado car and pag nag automatic switch yung aircon parang may "thug" na tumutunog sa right part (if you're inside the car ). Any advice on this? San b ok magpagawa ng MAZDA specially my case?
    imho, balik mo dun sa pinagpagawaan mo. baka nga related yan dun sa ginawang repair, not exactly dun sa fuel filter.
    open-type ba air filter mo ? hindi mo dapat marinig yung "thug" pag stock pa rin ang air filter mo. Check mo na rin at baka butas or worse, hindi naibalik nung lininis.
    I don't think the oil filter could cause the trouble unless it is the fuel filter that got replaced. Baka it needs some minor adjustment in the timing. How long before you performed the oil change ? Did you change the plugs, too ? Paano palyado ? kulang sa hatak or walang hatak ? if yes, malamang spark plugs.... HTH.
  4. Osiris Guest
    Thanks for the immediate response Protege and Happy_Gilmore. Ang pinalitan ko lang bro ay ung fuel filter (kaya lang nakita ko nakamark sa fuel filter e 626, same ba din sya sa 323 familia?), oil filter, drain plug, and langis. By the way sa Servitek near Casimiro sa Las Pinas ko pinagawa, ingat lahat dun at wala na yung mga magaling dun naiwan e ewan. Noticed na di marunong kasi hirap na hirap pagtanggal lang ng fuel filter at drain plug. binilog pa ung drain plug ko.
    Anyway, di ba di na tina-timing un kasi electronic na (please advise, not sure e)? Ano b yung servo? consulted some friends sabi baka servo. Sya nga pala yung air filter ko e yung stock pa. yung car nanginginig parang di ok takbo.
    Hindi kaya nagkaroon ng hangin sa fuel system mo? Baka kelangan lang i-bleed. I'm not exactly sure about the fuel filter pero malaki ang chance na pareho lang sila since parts like filter are rarely specially designed for a specific model para cost cutting.
    Pareho lang yata fuel filter ng familia at 626. Yung Japan-replacement kasi pareho lang.
    Nakakabili naman ng drain plug nyan. Hindi naman dapat sinisikipan ng pagkahigpit-higpit ang drain plug.
    Madami kasing pwedeng cause sa ganyang symptom. Tama ka at hindi naman kailangan i-timing pero ginagawa namin 'to kung may problem kami sa hatak, dropping idling and of course, emission.
    Anyway, if your problem(s) still persists, I could refer you to the south-based members and officers so they could assist you personally. E-mail me at admin*protegetech.org.
  7. Osiris Guest
    Sir Otep nang nagpalit ako ng fuel filter binuksan nila yung sa may gas tank para walang pressure. ano b tama process pagpalit fuel filter.
    Osiris,
    Hindi ko gaano alam for gasoline engines sir. For diesels kasi there is a bleed screw and a hand pump to prime the fuel system.
    Baka after the fuel filter nakapasok ang air (when they pulled the hose out).
    Jan 1970
    I think tama lang yun kasi pressurized ang fuel system ng EFI cars. If you don't depressurize the system before removing the filter, sisirit ang gasolina.
    if you want a full diagnostic, and surety of work, bring it to BALAI.
    medyo malayo lang because this is in Sto. Tomas, Batangas. pero specialist ang hahawak ng auto mo. look for Francis.
  11. Osiris Guest
    Salamat sa mga payo nyo bro M, irmscher, OTEP, Protege, happy_gilmore.
    Field report ko kung ano problem pag ayos na.
MAZDA Peeps HELP!!!
