Results 1 to 6 of 6
- Jan 1970
- 54
July 14th, 2003 10:11 PM #1guys yung friend ko bumili ng lancer singkit 2nd hand 110taw. chinek ko kanina the problem is pagnirev ko hangagang 3000rpm ang itim ng usok parang diesel. Natawa nga ako e!!! what do you think is the problem?:speechles
July 14th, 2003 10:13 PM #2
maybe needs a tune up?
worst... needs an engine overhaul to fix an oil leak.
July 15th, 2003 06:40 AM #3
alala ko dati yung lancer ko dati (dati means mga 93...)ganyan din...sira porma nung papuntang batangas...ang usok sa paghataw! ehehe anyway...tune up lang cguro yan...
July 15th, 2003 09:44 PM #5
also it would be good to have two different auto shops check the car unless you know a trusted mechanic.
- Jan 1970
- 54
July 15th, 2003 11:47 PM #6ok thanks sa mga reply. may alam ba kayo na magaling magoverhaul? makati area? or kahit san narin? salamat ulit.
high idle RPM at engine start
