Results 21 to 30 of 37
October 23rd, 2006 04:06 PM #23
Just a heads up, when you see the oil light lit up on your dash, turn the car off as soon as you get the chance to pull over, then check for the obvious and wait a little while before turning the car back on... There isn't any sort of warning when that light comes on. Also, it is one of those on your dash that lights up RED, and red means STOP!, if it was indicated as orange like an oil pressure light it would of been not as serious, but red doesn't take an account as to warn...
na-check mo na ba yung coolant mo? See if it's contaminated at all...
October 23rd, 2006 06:22 PM #24
*blink, paps, senxa..stupid question ulit...ano effect pag contaminated ang coolant? and how do you check whether it's contaminated or not?
October 23rd, 2006 06:40 PM #25
Kapag may build up sa loob ng coolant reservoir mo ibig sabihin contaminated ang coolant. Check mo rin yung radiator cap ~dapat wala ding obvious build up, kung meron, ibig sabihin may contamination nga... "Contamination" means may mixture ng oil and coolant... Isa sa mga signs of contamination eh yung puting usok na lumalabas sa tambutso...Also, kapag contaminated ang coolant mo, ibig sabihin may oil leak ka somewhere, most likely leak ~head gasket, but things may vary as well from case to case...
oh and there's nothing wrong with asking...
October 24th, 2006 11:40 AM #26
thanks again..just in case may oil ang rad, may leak kaya ung gasket? o dapat ipalinis muna ung rad then palitan ng bagong coolant/water, then observe muna kung magkaka-oil ulit? may white smoke din kasi during cold start ung oto..but nawawala din after mag-warm ang engine...sabi ng iba, normal lang ung white smoke during cold start, eh...thanks..
October 24th, 2006 03:16 PM #27
Try mo muna linisin yung radiator cap and yung pinaglalagyan niya... kapag nagkaron ng build up then possibly nahahaluan ng oil...that, Im not sure whether or not normal yon... My car doesn't blow white smoke during cold start, and none of the 3 other cars in the houselhold do... Another effective way to diagnose is to change the oil... Anong motor oil ba gamit mo??? Try something a little thicker, wait up to 3 days to see kung mawawala yung white smoke during cold start...
October 24th, 2006 03:54 PM #28
Mark, pa-compression test ka. Kung nagwarp yung engine head, pwedeng mahina hatak pag cold dahil hindi na completely flat yung head sa block, kaya pag warmed up it fills in the gap kaya ok na siya.
- May 2006
- 22
October 25th, 2006 11:08 AM #29Thanks ulit mga Bro,
I'm planning to do compression test pag may availabel time na ako.
BLINK, may relation ba sa paghinang humatak yung contaminated radiator?
AFRASAY, san ba exact shop address ng autotecnika? saan pa ba may nagse-service ng compression test? Anybody knows?
Thanks,
October 25th, 2006 12:25 PM #30
nasa shop address listing yun autotecnika. i think. pero madali lang makita pag lampas ng fairview market if coming from circle sa left side may metrobank ata yun katabi niya,
Xiaomi E-Car
