Results 1 to 10 of 10
    Nov 2006
    mga sir, may nakapag try na ba sa inyo ng ganitong combination? ano kya effect nito sa makina as well as sa performance? mahal kse ng belt tensioner sa casa eh. mas mahal pa sa timing belt. so, naisip kong bka pwedeng bumili nlang ng original timing belt from casa, then replacement belt tensioner nlang sa local sellers. car is a honda civic ESi... thanks in advance...
    Quote Originally Posted by wickednasty View Post
    actually, walang effect. nasa sa iyo na yan if you want to use replacements.
    ako nga, timing belt, water pump and tensioner eh replacement lang. mahal ang OEM.
    May 2007
    I agree with happy_gilmore, no effect on the engine. The only difference is that the life cycle of the original is a bit longer than the replacement.
    May 2005
    ako ang nilagay ko orig timing belt and replacement lang na tensioner and water pump. okay naman.... wala naman epekto yan, same performance at a cheaper price
    May 2004
    pwede naman yan. kahit nga both belts replacement ok pa din. as long as it's a good quality replacement part.
    Nov 2003
    replacement tensioners are ok as long as the brand of the bearing is a good one.
    Nov 2006
    ano po ba magandang brand ng replacement ba belt tensioner? may napagtanungan ako, NSK yung brand, i think around 700 lang...ok kaya yun? TIA..
    Nov 2003
    yup nsk is ok.
    May 2007
    Try the Gates brand the set cost around 2500 for honda civic esi, lxi,vti. it includes the belt, the tensioner bearing, the camshaft and crankshaft oil seal.
    Nov 2003
    stick with an oem belt imo.
orig timing belt and replacement belt tensioner...
