Results 1 to 10 of 10
May 11th, 2007 02:40 PM #1
mga sir, may nakapag try na ba sa inyo ng ganitong combination? ano kya effect nito sa makina as well as sa performance? mahal kse ng belt tensioner sa casa eh. mas mahal pa sa timing belt. so, naisip kong bka pwedeng bumili nlang ng original timing belt from casa, then replacement belt tensioner nlang sa local sellers. car is a honda civic ESi... thanks in advance...
May 11th, 2007 03:06 PM #2
- May 2007
- 11
May 12th, 2007 12:55 AM #3
May 12th, 2007 08:30 AM #4
ako ang nilagay ko orig timing belt and replacement lang na tensioner and water pump. okay naman.... wala naman epekto yan, same performance at a cheaper price
May 12th, 2007 06:45 PM #5
pwede naman yan. kahit nga both belts replacement ok pa din. as long as it's a good quality replacement part.
Tsikot Member Rank 5
- Nov 2003
- 3,849
May 15th, 2007 11:36 PM #6replacement tensioners are ok as long as the brand of the bearing is a good one.
May 17th, 2007 05:13 PM #7
ano po ba magandang brand ng replacement ba belt tensioner? may napagtanungan ako, NSK yung brand, i think around 700 lang...ok kaya yun? TIA..
- Nov 2003
- 3,849
May 21st, 2007 11:30 PM #9
Try the Gates brand the set cost around 2500 for honda civic esi, lxi,vti. it includes the belt, the tensioner bearing, the camshaft and crankshaft oil seal.
- Nov 2003
- 3,849
Na lock ang Gcash ko, need verification pa and kasama sa list nila ang philsys ID paper, but when I...
National ID Law
