Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Apr 2005
    Mga sir need your opinion at suggestion... Yung pinsan ko kasi nag text sa akin " bigla na lang daw pumupugak yung CRV... any suggestion kung ano magandang gawin? nasa malayong lugar kasi sya at ng hihingi ng advice what to do..
    thank in advance
    any other symptoms?
    smoke could be an indication na oil/water/coolant/a mix of any of the three could be entering the combustion process. has he been seeing any leaks around the engine block itself?
    Dec 2002
    dirty spark plugs or even a dirty air cleaner or even a clogged fuel filter when was the last check up and mileage
    Apr 2005
    Quote Originally Posted by nugundam93 View Post
    any other symptoms?
    sabihin ko to visual check his car...
    Quote Originally Posted by johnart View Post
    50k last PMS which includes change spark plugs, his running 52k right now... sabihin ko linisin na din spark plugs at air filter...
    Jan 2004
    linisin? bili na nang bagong spark plug at air filter.
    Sep 2006
    Hard to diagnose this on the internet.you can also check the maf sensor. How was the idle?
    Jan 2004
    agree with you m_ron.
    MAF sensor... hmmm. nagkakaproblema lang dun kapag nagmodify na nang Air Filter. sa LXi namin, ganun e. kala ko ECU na ang problema- yun pala, fouled-up throttle body.
    Apr 2005
    Quote Originally Posted by ian_rex View Post
    sir nasa malayong lugar saya kasi ngayun.. bundok... hehehe linis muna pag dating sa city tsaka palit...
    Quote Originally Posted by m_ron View Post
    text ko muna sir... post ko uli kung ano observation nya...
    check your fuel, baka nakargahan na diesel yan. D4D ba makina ng CRV? :p
    Apr 2005
    patay... naka modify nga yung air filter nya... knn
    Sep 2006
    Quote Originally Posted by arvic View Post
    i guess i nailed it.
    Apr 2005
    Quote Originally Posted by afrasay View Post
    nyahaha.... toyoda C-RaV...
    Apr 2005
    let's see sir... hhihihihi
    ah ok :D muntik ko ng ilipat dun sa isang thread.
    Apr 2005
    mukhang you nailed it hard sir... up and down daw yung RPM nya..
    Jun 2006
    Baka nalagyan ng diesel.
    Nov 2003
    CRV is map based. installing a filter should not be that hard to do and should not cause problems with the sensors.
    Sep 2006
    definitly maf sensor yan.
    OT:This is a common problem with later models mercedes the maf sensors goes south even if you have a stock air filter box.They just go south,next thing you know is your rpm is up and down.The maf sensor is made by bosch.
    pag hindi yung sensors try mo muna palinis yung throttle body and intake manifold
    Nov 2003
    again, crv's DO NOT have maf sensors.
    idle problems are cause by you IACV.
Gen 1 CRV 01 model pumupugak
