Results 1 to 10 of 19
- Nov 2002
- 30
December 1st, 2002 08:08 PM #1i had eibach prokit installed yesterday sa civic 96 vti ko... my prob is yung drop ng front n rear is different. sa back mga 2 finger gap n sa front mga 3 finger gap... is this a problem or di palang nag settle ang springs? kasi yung others na naka eibach pantay naman all around eh...wat could i do with this? tnx on advance!
- 166
December 2nd, 2002 09:28 AM #2Originally Posted by kt
- Nov 2002
- 30
December 2nd, 2002 11:46 PM #31.8! springs lang po to! :D is this normal? kasi higher yung front kaysa sa rear eh... pangit tuloy tingnan...:x so around how long kaya sya mag settle?
FrankDrebin Guest
- Nov 2002
- 50
December 3rd, 2002 07:55 PM #5Parang yung sa Corolla ko when I installed a set of Whiteline lowering springs (1.5" drop), nakatungo hehe. What I did was installed rubber lifters sa likod and got a pair of short struts for the front. Ayun, medyo pasubsob na yung stance niya, looks much much better...
- Nov 2002
- 30
December 4th, 2002 11:12 PM #6ayos pa naman daw yung shox ko eh...n others said na medyo ganun daw talaga yung ibang civic, lalo na pag di pa nagsettle yung springs...sana nga pumantay pag nag settle:cry:ayos pa naman daw yung shox ko eh...n others said na medyo ganun daw talaga yung ibang civic, lalo na pag di pa nagsettle yung springs...sana nga pumantay pag nag settle:cry:ayos pa naman daw yung shox ko eh...n others said na medyo ganun daw talaga yung ibang civic, lalo na pag di pa nagsettle yung springs...sana nga pumantay pag nag settle:cry:
December 5th, 2002 12:28 AM #7
ganon din bagsak ng auto ko before nung naka eibach pro-kit eh.. galant yung car...
feeling ko optical illusion lang yung di pantay ang bagsak kasi mas malaki ang fender sa front tires kaysa sa rear tires... i could be wrong though... paki correct nalang po kung mali :mrgreen:
- Nov 2002
- 30
December 5th, 2002 10:50 PM #8ssaloon! oh ganun din sa car mo? kasi sa rear mga 1-2 finger gap eh. sa front naman mga 3 finger gap! ganda na sana nung drop sa rear! pero di nga pantay sa front! so ano na nangyari sa drop mo now?
- 370
December 6th, 2002 09:16 AM #9Illusion lang yun.
The right way to determine the amount of lowering is to measure the car before & after lowering.
Also if you notice, almost all cars have a bigger front wheel opening compared to the rear.
It usually takes only a day or two of driving for the suspension to settle.
- Nov 2002
- 30
December 6th, 2002 09:08 PM #10auto_xer! oh ganun ba yun? kasi before 4 finger gap all around eh...now nga mga 2 finger gap sa rear n mga 3 finger gap sa front. so wat u mean is pantay na yun n illusion lang na di pantay?
high idle RPM at engine start
