Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Mga bossing,
    Have 2005 Fortuner 3.0V 140k mileage.
    Ask ko lang if may naka experience na sa inyo(kahit sa ibang car) or may idea ano possible problem?
    Starting up is OK(no grinding), when I shift to 'D' and move mga ilang meters, may malakas na grinding sound sa driver side engine. kapag walang tapak sa acceleration mga 4-5meters, kapag may tapak sa acceleration mga 2meters.
    Short to say basta parang umabot sa 5 KPH may grinding sound na parang sa gears. After tumunog ng 1-2seconds, smooth na ride kahit 100km itakbo no problem.
    Uulet nanaman siya kapag bagong start lang ang engine.
    Sorry for my other post, taking out starter problem as possibly ibang gears may problem.
    Thanks!
    how about if you accelerate? may naririnig ka pa din?
    Hi,
    wala na po noise when accelarating. Can run 100km or so without noise.
    Pero kapag inoff makina, then on ulet, first 5KPH nya magsosound or first few meters.
    Nabasa ko sa ibang forums, could be ABS system initializing at startup,pero medyo nakakatakot kasi ung grinding noise ng gears.
    parang squeek and hindi mashoot ung gear for 1-2seconds. Any suggestions as well?
    Dec 2007
    Kailan mas prominent or malakas ang tunog, pag malamig or maiinit ang makina?
    Kahit malamig or mainit makina, basta nagoff ka ng makina, tapos ni-ON ulet, sa first few meters, doon tutunog 1-2seconds tapos kahit gaano na kalayo itravel wala nang grinding noise.
    May related na ganito po sa US, Chevrolet cars, tanong ko lang dito sa Pinas baka may nakakaexperience din po at ano possible solution. Thanks po sa feedback.
    Startup Grinding Noise (Normal - It's the ABS Self Check)
    Quote Originally Posted by mikevin View Post
    possible nga na sa ABS, pero quite abnormal..... much better if you can have it checked.
    my current cars have abs, and one is a toyota.... wala namang ganun.....
    Oct 2013
    i vote AT fluid pump... or stuck up brakes...
    Aug 2010
    Experienced this as well with my previous vios, current altis then with a mirage. The altis is an AT while the rest are MT. Naririnig ko rin yun during first start up at yung unang usad ng sasakyan. Yung tunog niya is parang may "nag-engage".
    Seems normal after observing this from three different cars already. Yun nga lang, where the sound is coming from is still unknown.
    Posted via Tsikot Mobile App
    Boss Lyle,
    Ayun! Baka nga same tayo ng naeexperience.
    Parang may nag 'eengage' nga, lalo na first few meters. Pero kapag medyo LEFT ang kabig ng manibela, mas malakas tunog. Kapag straight lang, minsan hindi na marinig.
    Sa fortuner, nitrace ko, sa driver side na engine compartment ang tunog lage, nakita ko ABS nearest. Sa ibang auto baka iba iba location.
    Ano po solution na ginawa niyo?
    Thanks.
    Aug 2010
    Boss Lyle,
    Thanks.
    Pinabayaan ko lang mikevin. I agree may moments nga na masmalakas yung grinding noise. Hanggang sa nabenta na namin yung vios, may grinding pa rin. Pero never ako may pinalitan na piyesa because of the issue for the past six years I owned the car. So maybe it's really normal.
    Quote Originally Posted by Lyle View Post
    Boss Lyle,
    Ok thanks po sobra sa feedback and sharing your experience!
    Aug 2010
    Boss Lyle,
    You're welcome. Like you I'm also hoping someone could technically explain it better. But for now, I can attest nothing is wrong with your car based on my experience.
    Jul 2011
    Malakas ba ang brake dust, pwede wrap na ang disk, pag hindi makinis ang disk mo need resurface
    sent via LaTE Network
    Quote Originally Posted by Manilablock View Post
    Ok copy. Will check din po.
    Aug 2010
    Confirmed. It's the ABS engaging that causes the mechanical thunk.
    Sir, baka may solution ka din mashare diyan. haha.
    Medyo naimmune nadin ako, and kept it away from turning left nalang at start, para less thunk.
    Jul 2014
    Pag EBCM o ABS module ang nasira walang break.. Pag umilaw pwede WSS kc ang Toyota ay may model na built in ang sensor sa wheel bearing sa rear.
    Tsikot Mobile App
    Quote Originally Posted by mrjeff View Post
    Tsikot Mobile App
    Sir, walang umiilaw pa naman so far, medyo irritating thunk lang o 'engage' sa first few meters every start. Especially when turning left, kapag gitna o right, sobrang hinang 'engage' lang.
    Oct 2009
    Abs yan. Acheck mo manual mo
    Quote Originally Posted by harold13 View Post
    Thanks Boss. Yes po, medyo irritating lang,kasi minsan medyo malakas ung 'engage' ng ABS.
loud grinding noise when reached 5KPH, once every journey
