Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
    #21
    Quote Originally Posted by pajero gmbh
    based on my observation. pagbagong takbo naddagdagan resoirvoir ko tapos pag cooldown na bawas na sya. tama yun diba? but everytime i open the radiator cap kulang sya sa 2big hindi puno. based on my test while engine is running i open the rad cap tapos every 10sec to 15 e may bula. hindi lumulobo na parang bubbles. parang blok!!! isang malaki lang. what might be the problem? but minimal lang ang bawas.
    Bleed the cooling system from air as what lakay says.
    Pag di pa nakuha, me singaw ka pa rin somewhere...yung compressed gases from the combustion chamber tumatagas sa cooling system kaya may bula. Monitor mo yung water sa radiator kung nagkakalangis-langis and your oil naman kung nagkaka tubig.
    Mar 2004
    #22
    walang humahalong oil sa radiator ko. and water sa oil. sige i will bleed muna and replace rad cap. give you sirs feedback after.
    Jun 2004
    #23
    Mga Sir... pano naman pag lumalabas water pag open yun radiator cap? I change na the thermostat ganon parin tapos newly overhaul radiator... pag wala thermostat rotating naman yung water... ano kaya problem nito? many thanks
    #24
    up ko lang to mga sir... ganitong-ganito kasi nangyayari sakin ngayon.
    diesel sportage ko din nang tubig sa radiator, pero hindi sa reservoir. if i let the engine run without the rad cap, may fine bubbles na lumalabas sa filler neck. diba dapat wala talagang hangin na lalabas don? i'm suspecting my head gasket to have a small leak. pano ba malalaman kung leaking na talaga yong gasket ko.
    maraming salamat po...
Losing water on my paj
