Results 1 to 5 of 5
    Nov 2006
    I noticed a small pool of atf on the floor (drivers side) and took the car to the mexhanic at shell. Once we got there the leak just stopped !! He messed around under the car and when we came home at night there was a new leak(a smaller one on the passenger side) ?? Im going again to a new place now. Maybe its a leaking clamp or gasket or something!!
    Aug 2006
    your vehicle sir?
    Aug 2005
    try engine wash and under wash then observe mo uli..
    Nov 2003
    leaks wont start and stop. dapat dere derecho lang yan. baka di lang makita ng mechanic mo where it is comming from.
    Dec 2003
    ewan kung may available locally, i use Leakfinder to find hard to spot leaks, using different dyes which can be used on engine oil, trans oil, coolant n ac leaks. it uses a uv light to find the leak.
    i bought it online from states.
Leak appearing and dissapearing !
