Results 1 to 7 of 7
    Jun 2007
    I have a Civic 96 A/T. Why is it at initial startup masyadong matagal bago mag engage ang reverse gear (minsan inaabot ng 10secs)? Pero sa reverse lang naman. Ang ginagawa ko nagpupunta muna ko sa D4 then balik sa reverse para lang mag engage sya.
    My ATF seems ok naman.
    Tnx in advance
    Nov 2003
    replace the atf parin. that should always be the 1st step when something is wrong with the tranny.
    Jun 2007
    Thanks SpeedyFix
    Any brand that you can recommend? Last time I changed my ATF I used AC Delco.
  4. #4
    brand is next to ATF type... baka maling type ang ginagamit mo..palit ATF muna..if symptoms persist, see an ATF-expert(kala mo doctor noh!)
    isa sa symptomas na naranasan ko yan sa liteace ko delayed R, then nung pinalitan ko,ganun parin, tapos umiinit ang makina, then D naman, pinalitan ko na AT mismo, masmura kaysa sa overhaul,e...
    Jun 2007
    Tama naman yung ATF type na ginamit ko. DexronIII . I checked the manual before I changed it. Palitan ko na rin ulit para sure na hindi nga sa ATF
    Tnx
  6. #6
    baka kulang?? ang tamang way ng pag-check ng atf, dapat nasa operating temp. at running ang engine... sa N ang lever..(be sure naka handbrake....)
    Nov 2003
    motul, mobil and castrol yung gamit namin
Reverse Gear Delayed
