Results 1 to 16 of 16
    Nov 2003
    hello...
    advice naman po..
    nagoverheat kanina yung makina ko..
    then dinala sa talyer...
    sabi kailangan daw palitan ang water pump kasi may tagas..
    then magpapalit na rin ng radiator hose at gasket...
    tapos kailangan daw ng bagong cylinder head kasi may bula daw, parang leak ata dun nung pinalitan before yung valve seal...
    ndi ko sure kung dapat bang ayusin yung leak.. which means magpapalit ng ng cylinder head..para maayos ang oeverheating problem?
    the quote is 10K for this whole problem..is it reasonable?
    please advice..thank you..
    Nov 2003
    by the way...Centennial Auto Services Inc. pala yung shop..sa may Makati..
    thanks..
    Dec 2003
    tawaran mo 7k or 8k at the most pwede na
    A replacement water pump costs 1k more or less from what i know (CMIIW). If you have a damaged water pump, the usual symptom is you lose water WHILE the engine is running.
    Mar 2005
    I suggest that you take it a more reliable talyer for a second or third opinion. Maraming tsikot forum members dito ang may talyer na ok. Sounds like rumaraket yang talyer mo.
    Aug 2003
    1800 yung water pump ko. FYI. GMB yun, "reputable" replacement.
    i assume when you say "cylinder head" you mean cylinder head GASKET. 600 ang replacement nun. mahal kung cylinder head talaga :D
    Dec 2003
    magpapalit daw ng cylinder head..
    Nov 2003
    salamat sa mga advices/comments..
    eto yung quote sa akin...
    water pump - 1450
    cylinder head - 1200 ...ndi ko sure kung head nga talaga...
    radiator hose - 550
    gasket - 800
    labor for the change of pump, installation of hose - 1500
    labor for cylinder installation - 2500 ..kasi ibababa daw ang makina
    machine shop - 1200..kailangan daw ipamachine shop..
    yung mga may talyer na tsikoters...please PM or post na lang..
    baka in the future sa inyo na lang ako pagawa...
    thanks..
    Aug 2003
    diba sobrang mahal ng cylinder head?
    ang alam ko ito yung buong upper part ng engine block eh (the part with the valves and stuff) na nag-wa-warp pag nag-overheat ang engine.
    with that pricing, baka nga cylinder head gasket. :P
    Aug 2005
    ang mahal naman.. kung hindi pwde tawad punta ka iba shop yong reliable magtrabho and may ma save kpa.
    Parts ok lang price, pero labor maha. Dapat sama na yung cylinder head sa waterpump change.
    Potang labor yan ang mahal!!! Pati yung parts medyo mukhang padded na ang presyo...
    Madugo ang charge niya sa labor. Yung parts siguro, ikaw na lang bumili.
    hanap ka ng ibang talyer...masyadong mababaw ang diagnosis "may bula" lang eh sira na agad ang diagnosis sa cylinder head.
    Definitely merun possibility pero masyadong mababaw na dahilan yun. Gaanu ba ka overheat ang oto...as in itinirik ka ba at hindi na gumana ang oto? me langis na ba sa tubig ng radiator?
    Nov 2003
    salamat po sa mga comments...mahal nga e..
    namatay kasi yung makina bago dumating sa parking lot..sa may landmark..
    ndi naman umusok pero nasa red na yung gauge nya ng temperature..
    no choice kasi ako nun kasi nung pag pinaandar, after few minutes, back to red na naman..
    i've searched a repair shop thru net kasi not familiar sa makati area...
    then nakita ko nga tong shop na ito..
    pinaTOW ko na kasi pag senerbisan daw same din ang charge na parang na towing...
    sana OK naman ang gawa...
    Sep 2004
    Parang diagnosis ng mga gustong mangharang.
    Tingin ko hindi naman basta nagwawarp yung cyl head kung minsan lang nag-overheat. Kung biglaan, it could be the water pump.
    Ubos ba talaga ung tubig? Kumukulo ba sa may overflow reservoir?
    Better bring it to a reputable shop that tests thoroughly and carefully.
    Goodluck.
water pump replacement, etc...
