Results 1 to 10 of 18
- Apr 2007
- 42
August 30th, 2007 12:00 PM #1had my car engine washed last tuesday at sabi ng nag hugas may langis raw sa mga sparkplug/sparkplug holder ng kotse ko...suggestion ng bro ko ipa top overhaul ko raw...
ano po ba maganda gawin...im planning to bring my car sa mekaniko this weekend...pls help.TIA
August 30th, 2007 09:01 PM #4
bakit naman kailangan i top overhaul e ang sabi yata ng nag engine wash ay spark plug holder ang may oil so depende sa car or engine baka me leak lang valve cover (i doubt if it;s the spark plug kasi nag pa wash ka lang and they don't need to remove the sparkplugs)
Zombie
- Aug 2006
- 728
August 31st, 2007 12:07 AM #5baka ibig sabihin nung carwash boy mo eh may tumutulong langis sa gilid gilid ng engine mo, at naiipon sa spark plug holder. malamang gasket yan.
Tsikot Member Rank 5
- Nov 2003
- 3,848
August 31st, 2007 08:10 AM #7if it is at the tip then normally it is the valve seal that needs replacing. kung sa tip when the high tension wire goes in then it is the sparkplug oil seal.
get it checked well before getting an overhaul agad.
- Apr 2007
- 42
September 1st, 2007 05:26 PM #8sabi nga rin ng mekaniko ng car ko try ko muna compression test kasi wala naman ako nararamdaman na kakaiba sa takbo nito...out of town kasi mekaniko ko e. salamat po sa mga nag reply.
September 2nd, 2007 02:36 PM #9
yup, choose lesser evil. have it checked muna before jumping into great repair. now, since malinis na engine mo, observe kung san talaga nanggagaling yung oil. good luck at wag sana major sira yan
- Aug 2007
- 5
September 2nd, 2007 10:38 PM #10malamang spark plug oil seal yan, nalutong kasi yan sa katagalan. check mo na rin valve cover gasket baka may leak na rin.
soy-based wire insulation. 1. cheaper than the petroleum-based plastic insulation. 2....
BYD Philippines
