Results 1 to 6 of 6
July 7th, 2003 01:41 PM #1
1. what are the possible causes?
2. what is actually happening? (looking for a relatively technical answer)
3. what is the recommended solution to fix it?
July 7th, 2003 02:19 PM #2
One answer, tuffet adjustments.
Valve seats not properly seated can and could cause to make some knocking sound. Valve clearance needs re-adjustment after some period.
July 7th, 2003 06:22 PM #3
Bossing Logbook,
This might answer your questions
http://zhome.com/ZCMnL/PICS/detonation/detonation.html
July 7th, 2003 06:59 PM #4
When i experience detonation, is usually check the following:
- fuel (switch to higher octane or another brand)
- ignition timing (check and retard by around 2deg)
- spark plugs (switch to one heat range colder)
These are the usual culprits that can be singled out first before going on to other possibilities.
