Results 1 to 6 of 6
July 7th, 2003 01:41 PM #1
1. what are the possible causes?
2. what is actually happening? (looking for a relatively technical answer)
3. what is the recommended solution to fix it?
July 7th, 2003 02:19 PM #2
One answer, tuffet adjustments.
Valve seats not properly seated can and could cause to make some knocking sound. Valve clearance needs re-adjustment after some period.
July 7th, 2003 06:22 PM #3
Bossing Logbook,
This might answer your questions
http://zhome.com/ZCMnL/PICS/detonation/detonation.html
July 7th, 2003 06:59 PM #4
When i experience detonation, is usually check the following:
- fuel (switch to higher octane or another brand)
- ignition timing (check and retard by around 2deg)
- spark plugs (switch to one heat range colder)
These are the usual culprits that can be singled out first before going on to other possibilities.
high idle RPM at engine start
