Originally posted by router
i noticed that when i apply the brakes (half pressed) i here a kalatok sound... parang may sirang bearing sa may disc brake when i had it checked wala naman moving parts sa under chasis that could produce the sound except for the CV joint that gives me a single kalatok sound when i rotate the wheels.. sabi mechanic normal lang daw yun... play lang ng cv joint... totoo ba ito... i'm thinking the brake pads needs replacing pero nung check namin makapal pa naman...
Sounds like a problem somewhere in your suspension and not from the CV joint. I've recently replaced my car's CV joint and the sound that comes from it is a "tok-tok-tok" whenever you are driving around a curve or taking a turn. Check for worn out rubber bushings, those usually are the culprits as how you described your problem.
