Results 1 to 7 of 7
    May 2005
    guys, pwede bang manggaling ang kalampag sa front springs or shock mounting?
    nagpalit na ako ng bagong shocks pero meron pa ring kalampag na naririnig. ang di ko na lang napapalitan ay rack&pinion. honda city 98 ang oto ko.
    thanks.
    Assuming di ka pa nagpapa-repair ng suspension, to eliminate kalampag in a car that old, you will need to replace:
    1) Tie rod end and rack end (the usual culprits)
    2) Ball joint (although sa Honda mahal since the ball joint is connected to the lower arm, unlike toyota separate yung ball joint sa suspension arms)
    3) Arm bushings (palit din to buo)
    4) shock tower bushings
    5) stabilizer links (sa likod)
    Sep 2005
    Quote Originally Posted by magnus
    thanks.
    yes sir front springs and shock mounts culprit din.
    pero usual dito ay mga ball joints, rack end, tie rod end, busings, etc.
    have it checked para di ka palit ng palit.
    May 2005
    thanks for your replies.
    Jun 2005
    dalhin sa cruven ;)
    Mar 2003
    saan kaya nakakabili ng leafspring bushing and may upper/lower bushing pa ba para sa rear shocks kasi diba built-in na sa shocks yung mga bushings? at kapag nagpalit ba ako ng rear shocks and bushing kailangan pa ba ipa wheel alignment/camber?
    whats your car?
Kalampag question
