Results 1 to 7 of 7
- May 2005
- 66
January 19th, 2006 04:03 PM #1guys, pwede bang manggaling ang kalampag sa front springs or shock mounting?
nagpalit na ako ng bagong shocks pero meron pa ring kalampag na naririnig. ang di ko na lang napapalitan ay rack&pinion. honda city 98 ang oto ko.
thanks.
- Nov 2005
- 251
January 19th, 2006 04:23 PM #2Assuming di ka pa nagpapa-repair ng suspension, to eliminate kalampag in a car that old, you will need to replace:
1) Tie rod end and rack end (the usual culprits)
2) Ball joint (although sa Honda mahal since the ball joint is connected to the lower arm, unlike toyota separate yung ball joint sa suspension arms)
3) Arm bushings (palit din to buo)
4) shock tower bushings
5) stabilizer links (sa likod)
January 22nd, 2006 10:18 PM #3Originally Posted by magnus
pero usual dito ay mga ball joints, rack end, tie rod end, busings, etc.
have it checked para di ka palit ng palit.
- May 2005
- 66
Tsikot Member Rank 3
- Mar 2003
- 637
January 27th, 2006 04:57 PM #6saan kaya nakakabili ng leafspring bushing and may upper/lower bushing pa ba para sa rear shocks kasi diba built-in na sa shocks yung mga bushings? at kapag nagpalit ba ako ng rear shocks and bushing kailangan pa ba ipa wheel alignment/camber?
