Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Jan 2004
    Dahil nakalimutan kong i-check bago bumiyahe ng malayo, naubusan po ako ng windshield washer liquid.
    Ngayon even after filling it up, the water doesn't shoot out to the windshield. Instead it just flows into the hood.
    Ang tanong, nagbara kaya ang hose dahil nahigop ang dumi? I would think hindi yata kasi mas-mataas naman ng konti yung butas para sa hose kaysa dun sa bottom of the reservoir.
    What else could be the problem? I've tried pressing the control a few times successively. I thought maybe that the water just hasn't reached the end.
    Kung nagbara man, can this be "DIYed"?
    TIA.
    Jan 1970
    Try mo tusukin ng karayom yung holes nung nozzle
    Yep, malamang nahigop niya ang mga debris sa bottom ng tank mo. Konting tusok ng aspili or karayom lang yan. :D
    Karayom always does the trick! ;)
    Jan 2004
    Mukhang may gunk nga na bumara sa nozzle, pero malalim. Tinusok ko na ng staple wire, lumubog naman. Yung tubig tumatalon na pero mga 3 inches lang.
    I think I need a longer implement, or I have to take out the nozzles and clean them. Is this an easy task? Madali bang ibalik yung hose pag tinanggal?
    Palitan ko na kaya nung may ilaw. Hehehe joke.
    Disconnect mo na lang yung water hose. Kapag napush back mo na yung gunk, try blowing into the nozzle.
    related question, where, normally, is the location of the pump for the windshiled washer? Kung meron nga syang pump.
    Thanks
    Teka, check mo lang yung clear hose from the washer to the nozzle, baka may naipit lang, if you operate the washer na nakabukas yung hood, malabas ba tubig? If so, may naipit lang na hose.
    Jan 2004
    Ang problema only part of the hose is clear. Madumi na yata. Kelangang ipa-detail sa Big Bert's. Hehehe.
    I tried with the hood open and it's still the same. So it's either the nozzle or the hose part between the container and the hood hinge. Anyway I have the nozzles here with me and I'm cleaning them just the same.
    Regarding the "pump", don't know if it's called a pump pero may parang canister na may marking na "DENSO" katabi mismo ng washer fluid container.
    Aug 2003
    what about leaks in the windshield washer tank? i have a pretty bad leak (all the water gets consumed overnight) but the tank is hidden, can't get at it.
    May 2004
    need your help too guys. mine is working just, i just noticed after ko magpapalit ng alternator di na gumagana yung pump ko. connection sa pump is ok. i'm just not sure yung from pump to alternator/battery.
    appreciate your help.
    thanks.
    Jan 2004
    Update: ok na yung isa. Yung isa na lang medyo barado kahit hipan. I think I need a compressor to blow the dirt out. But I don't have one now. Try ko muna if baby oil or alcohol can carry the dirt out.
    Dec 2003
    Hi Clif,
    You can remove the hoses, just be careful if its an old car. Please see my post below, maybe we had a similar problem.
    http://daihatsuclub.proboards2.com/i...num=1090256676
    Jan 2004
    Thanks. Luckily the hoses weren't as brittle as I thought it would be. (Unlike the ones used for say LPG gas tanks.)
    So I was able to easily remove them and put them back on. Today the left nozzle is ok. The right though, still only pushes water out to the lowest part of the windshield with very little pressure even after several pokes with a pin. I will take care of this this weekend with the compressor thing.
    Thanks for your help!
    orly_andico, are you sure it's the tank and not the hose? If you can't get at it I suggest you look at it when you have an underwash at the gas station where it will be lifted. There's probably a good epoxy appropriate for water and can withstand the heat from the engine. I'd replace it with a surplus if I can find one.
    silhouette, looks like it's an electrical problem if you recently changed alternators.
    di pwede epoxy dyan sa plastic container at mababasag lang yun sa vibration. buti pa gamitan mo ng silicone sealant na high temp.
    You can re-align the nozzle spray by using the needle and aim it correctly. This takes time and patience.
    try mo muna WD40 spray mo sa outer side using the supplied red nozzle.
    Jan 2004
    Update:
    Had the nozzles taken out again and blown with compressed air sa gas station. Ayos na! Lakas!
    And yup, kailangan nang iadjust pababa with a needle kasi mataas na yung tubig.
    Thanks a lot guys!
    Mar 2003
    Barado yung isang butas...
    Paano linisin ito?
    Tnx...
    Buy a new pair of Brabus washers?
    Teka di ba meron nang nagkaroon ng same problem yan dito sa tsikot?
[Merged] Windshield Washer Problems
