Results 1 to 14 of 14
    Hello to everyone. I need help with my car's transmission. Kumakalas yung first gear niya. All the other gears are fine. Pinababa ko yung transmission ko dahil sabi ng mechanic ay baka yung "synchronizer" daw ang may problema. Nang mabaklas na yung transmission ay nakita namin na ok pa naman lahat ng mga synchronizers at mga ngipin ng gears. I got a second opinion from another mechanic and ganon din ang sabi na wala raw problema sa synchronizers. Since nakababa na rin lang yung transmission at medyo marami na ring mileage yung kotse ko ay pinapalitan ko na lang lahat ng parts sa loob ng transmission ng japan surplus (cost me 3K) hoping that the problem will be fixed pero kumakalas pa rin siya sa first gear. Ano kaya problema ng transmission ko? Help.
    Aug 2004
    Anong kumakalas? It pops out of first gear? Might be a bent shift-fork (although not knowing your vehicle, I can't say for sure).
    Sayang yun... if nothing was wrong with your gears or synchros, you shouldn't have swapped them out.
    What car?
    Aug 2005
    Worn clutch maybe? :confused:
    Hmmm had a problem a month ago na with this din. Baka maluwag na ung gearbox mo kaya di na kumakagat
    What car?
    Thanks for the advise. My car is a Nissan Sentra LEC 98 model. 90K na yung mileage niya. Pag nag shift ako sa first gear at nagbigay ng gas, nag-jujump yung gear to neutral. Pero pag hinahawakan ko yung shift knob ay napipigilan naman siya. Wala rin daw tama yung shift fork according sa mechanic.
    Quote Originally Posted by Kapitan View Post
    How was your problem fixed? Did you replace your gearbox? Kailangan ko na kayang palitan yung bung transmission ko? Nagcanvas na rin ako sa Banawe. Mga 6K yung Japan Surplus. Any other ideas? Thank you.
    Sounds like a damaged 1st gear. You will need to replace the 1/2 gear.
    I had a similar problem where the manual tranny will not stay in 3rd gear. They replaced the 3/4 gear. This will require the tranny to be pulled down and openned up if you opt to replace the broken gear. The alternative is to get a surplus tranny and swap that in.
    Sir GH, pinapalitan ko na ng surplus yung mga gears (isang buong assembly) pero ganoon pa rin. Meron ba kayong mai-rerecommend na transmission specialist? I'm already thinking of replacing the entire transmission dahil parang walang mekanikong makapagsabi kung ano ba talaga sira. Thanks ulit sa advise.
    Nov 2006
    Quote Originally Posted by fastlane View Post
    fastlane: bago ka magjaump sa conclussion icheck mo muna kung anong type ng transmission linkage equipped ang kotse mo kasi merong two types ang linkage nito,,,,,,,extrnal shift rod and internal shift rail,,,,,pareho lang ito ng function but they different parts and palagay ko gears has nothing to do with problem (grinding noise or jump out of gear,first gear only) and sabi mo pag pinigilan mo yung shift lever ay nawawala ang problema, marahil ay may kinalaman ito sa shift linkage mechanism,ipacheck mo itong mga sumusunod:
    for external shift rod:
    =1st and 2nd shift rod could be bent or its hole thru shift fork lever could be oversized or its pin.
    =shift lever mechanism to 1st and 2nd shift rod its hole for 1st gear might be worn out or the adjustable swivel might be worn ou to.
    for internal shift rail:
    =1st and second shift gate it could be lose or worn out.
    =shift rail could be worn or weak detent spring.
    for both:
    =shift lock for 1st gear could be missing.
    =improperly adjusted shift linkage for 1st and 2nd gear.
    sana makatulong ito sa iyo para di ka makagastos ng malaki.
    Nov 2006
    sensya na sa grammar ko dahil sa pagmamadali nag ala barok tuloy ang grammar ko.
    Quote Originally Posted by dennis powell View Post
    HAHAHAHAHA!!! natawa ako dito. Malamang walang problema tranny internals. Nasa linkage yan. Check mo rin yun mga plastic (kung mayrun) bushings.
    Nov 2006
    Quote Originally Posted by afrasay View Post
    afrasay; nakikita kita sa computer ko,tinatawanan mo ang grammar ko,and kung di ka pa hihinto sa katatawa mo ay ibubulgar ko sa buong mundo na ikaw si spiderman,sige ka .....hehehehe joke lang.
    masapot ba :D
    for both:
    Salamat sa advise. I'll ask again my mechanic to look into those parts you've mentioned.
jumping from first gear
