Results 11 to 20 of 25
May 3rd, 2006 12:02 AM #12
umm... ok... so... if I have a stock engine, using iridium plugs won't increase power nor improve mileage, but will lessen the need to replace the spark plugs every tune up... right? I have an Altis, so NGK or DENSO?
Tsikot Member Rank 5
- Nov 2003
- 3,848
May 3rd, 2006 12:23 AM #13nah not really. on modded engines tho it's a decent mod. makes up one of the 3 main principles of producing power:
fuel
air
spark
plus, with modded engines you've normally spent a lot on other things narin that 2k+ for plugs is a decent amount na for keeping everything working well.
- May 2005
- 225
May 3rd, 2006 12:32 AM #14if intending to use these plugs on a tuned car, just make sure that your engine won't run a rich air/fuel mixture.
- Jun 2005
- 215
May 3rd, 2006 11:39 PM #15Originally Posted by pitbullz
- Jul 2005
- 53
May 3rd, 2006 11:40 PM #16NGK Iridiums are stock plugs for my ride. Works well. I have a turbo engine and my first tuneup was 30 months from date of purchase or 24K kms later.
- Feb 2006
- 20
May 15th, 2006 04:33 PM #17I have seen the spark of the ngk Iridium and ordinary plug,
there is an exhibit in Japan comparing the two, iba ang spark between the two sa iridium.... its a very small arrays of sparks so medyo malaki yung area nya
doon naman sa ordinary one point lang ...so its also helps in the combustion
so hindi lang naman siguro dahil sa harder metal, it will affect complete combustion of your fuel.... cleaner exhaust gas and fuel efficiency....
May 15th, 2006 05:09 PM #18
it is a waste of money if you have a stock engine (that doesn't require one).
though the Rav4 & Cefiro have OEM Iridium Spark Plugs that are rated to last for 100K km. aftermarket Iridiums can only run for 20-30K km.
May 18th, 2006 12:14 AM #19
Originally Posted by mazdamazda
...ayus ahh!.. up to 100k??? ...to much I think! aftermarket plugs for 20-30k kms only? ngeeekk!! ..how could that be?..
eh di OE ng Rav4/Cefiro na lang bibilin ko!!..harharhar!!...
May 18th, 2006 02:58 AM #20
using denso iridiums on our AE101. di ko maramdaman effect. di na kasi stock yung engine.
I received this email from Fleetguard Understanding coolant and recommendations I think this...
