Results 1 to 19 of 19
    Feb 2006
    Mga bro, what are the ill effects of overfilling your engine oil? Kase, my mother-in-law's car (civic vti 99), when I checked dipstick, the oil level was way above the high level (parang 1/2" higher). I noticed oil leaks na sa cylinder head cover (maybe because sobra nga oil, naghanap ng lalabasan yung oil -- tama ba?). What other parts kaya affected? Thanks in advance!
    mababasa mga plugs, leading to poor running, baka din masira mga valve seals at plug seals.
    Dec 2003
    i read somewhere magkakaroon ng oil starvation below DAW
    Oct 2005
    yup. maghahanap ng outlet yung excess oil. pressurized ang oil na yan when the engine is running so kapag umaandar, aapaw talaga sya. thus, marumi ang engine bay mo...depending on how much oil is INXS.
    Feb 2006
    Quote Originally Posted by BlueBimmer
    Thanks guys.
    Sir BlueBimmer, what's "oil starvation"? Pls excuse my ignorance
    Thanks
    Feb 2006
    Quote Originally Posted by theveed
    Pag nasira plug seals then basa ang plugs. Checked plugs, may konting oil nga. So sira ang plug seals. How would you know naman if sira ang valve seals? Any indications? Thanks again
    pero yung kotse ko.. nung last time ay overfill din ang oil. nag excess dun sa max... pero wala namang naging effect. 10K kms ko ginamit before ko i change oil ulit. Ok naman, wala naman naging effect.
    In a short period walang effect yan but in the long run yun seals mo mag leak.
    May 2005
    tama iyon mag build up ng pressure sa loob at maghahanap ng malalabasan ang oil.
    mga pwede masira plug at valve seal,engine gasket
    Aug 2005
    sabi sa manual ng car overfilling could damage your engine.
    one of it is, someone told me na magiging mausok ng konti yung chikot mo!
    Quote Originally Posted by pomelo
    Alam ko those plug seals are like rubber o-rings, and with too much oil pressure, they will bust and let oil into the plugs. If this happens, replace the o-ring(s) concerned. Buy original since the material of replacement ones are too hard such that it will get busted sooner.
    For other leaks, just look around your engine where oil is coming out. The rubber parts in those areas may need replacement as well.
    Nov 2003
    no major effects naman. just a slightly more sluggish engine because there is more resistance because of too much oil. aside from that, dapat naman lumabas sa breather yung excess oil. simplest solution would be to drain the excess.
    Aug 2005
    ito pa na experience ko na yung overfilling dahil nilagyan ko pa ng oil additives nag busted yun valve cover yung rubber. possible din na valve seals ang masira.. where nka locate yung o-rings? pag busted o-rings mausok ba?
    ang pinakamahirap nito ay yun seal ng driveshaft ang masira. hirap palitan. stick to the manufacturer's specs nalang.
    Apr 2004
    It might damage your catalytic converter if you have one.
    Oct 2004
    crank skaft counter weights touching the oil level equates to at least 5HP power loss...
    another thing is that if ever oil is way above the normal level, bubbles develop inside the engine... thus, oil starvation occurs because of the bubbling oil...
    May 2005
    question: habang umaandar yung engine mo, tapos chineck mo dipstick mo,normal lang ba nasa low level yung oil? ty
    Nov 2003
    check when the engine is off...
ill effects of overfilling oil?
