Results 1 to 10 of 11
- Jun 2005
- 50
October 4th, 2007 10:53 PM #1plano kong tanggalin ang roofrails ng sasakyan ko,
crv gen1 and ford explorer (not sporttrac)
gusto ko kasi subukan un on-road look...
meron na ba nakagawa nito?
October 5th, 2007 07:44 AM #2
Wag mo ng tanggalin kasi may butas na yang pinagkabitan ng roof rail kung ibinarena yan.
October 5th, 2007 08:09 AM #3
Actually it ain't really rocket science to remove roof rails. I did it twice na, once on a car that used only 3M double sided tape and the other that used drilled bolts.
Medyo matigas rin ang 3M mounted, super strong but it can be removed. I slowly twisted lang on the mounts until I could see the tape then I car carefully sliced it off in a peeling motion. When they were completely removed, the most difficult part was trying to remove the 3M left on the roof itself. After trying real hard not to scratch the paint surface, there was still a good number of portions next so I just had it sanded-off completely and spray painted again.
So goes for the bolt mounted type. Kailangan talaga ng body filler and repaint din but it is only a half day job. No big deal.
October 5th, 2007 08:16 AM #4
ipatangal mo sa talyer, dahil pagkatangal niyan sigurado may butas at kailangan masilyahan at pinturahan... kung hindi papasukan ng tubig ang sasakayan mo kapag umuulan... at saka pagmumulan iyun butas na iyan ng kalawang...
sayang tama si Syuryuken whag mo na tangalin roof rail...
- Nov 2006
- 263
October 5th, 2007 08:32 AM #5took my roofrail off of my expedition and i actually like the whole street truck look.
i just took all the screws off and i used teflon tape,wrap the screws with teflon tape and put the screws back to where the holes were.the screws are flushed so no one even sees them.
as far as leaks?..ive had them for two winters now and still not a leak inside my truck.
October 5th, 2007 11:57 AM #6
kung OEM naman na sasakyan, madali lang alisin then may covers na din yan...
hay for the name of "look"..kasama sa binayaran mo yun,e...
pwede bigay mo nalang sa akin roof rails mo :naughty2: ayaw mo naman na nun,e...Last edited by alwayz_yummy; October 5th, 2007 at 12:06 PM.
- Nov 2006
- 263
October 5th, 2007 12:05 PM #7yup.its part of what i payed so that means i can do whatever i want with it,right?
and its not just all look neither.the engines packing bout 600HP too so nothing heavy is allowed in the truck
you can have the roof rack for 50$ if you want.i dont use it and dont intend to put it back in the truck anymore.
- Nov 2006
- 263
- Jun 2005
- 50
October 5th, 2007 11:16 PM #10nakapag-decide na ako
iiwan ko nalng un roofrails..
pero nagpa-estimate ako sa ford casa
15k daw lahat lahat fyi
^ geo yatta of bulacan, ang nagcause ng traffic sa NLEX eh hinid minimum wage earners. Mga...
Traffic!
