Quote Originally Posted by Bry View Post
1. CROCODILE JACK (5T) - P2,000-4,000
2. ANGLE GRINDER (MAKITA) & IMPACT ELECTRIC DRILL (MAKITA) - each will be around P5,000 so total of P10,000
3. SOCKET WRENCH SET (10-12 MM) U.S. OR GERMAN - each is about P300 so total of P900
4. DEEP SOCKET WRENCH (12-30 MM) U.S. OR GERMAN - each is price between P300 to P700, mahal yung malalaki na 300mm and consider the arm ng socket wrench that is another P1,000, so for this group I estimate about P3,000 to P5,000
5. STEEL STAND (1 SET) 4 PCS. - about P300 to 600 each depending on height mas mahal yung mataas na about 12" yung body, so total of about P1,200 to 1,600
6. CROSS WRENCH H.D. - about P200-500
7. HAMMER BALL H.D. - depending on size average cost is P400
8. PHILLIP SCREW SET & FLAT - each is about P100 so depende kung gaano kadami ang bibilhin mo
9. COMBINATION BACK WRENCH H.D. (10-24 MM) U.S. OR GERMAN - a good brand is about P1,000-1,500, bihira nga pala yung set na merun aabot ng 24mm
10. PLIER & LONG NOSE - about P300 to 500 each depending on size
11. CHISEL (SINSIL) H.D. - a good one na hindi basta-basta pupurol ay abou P200 to P400
12. VALVE LIFTER - i haven't bought one like this pero probably between P500-P2,000 eto
13. PISTON RING GRIPPER - i think a generic one is about less than P500
14. TORQUE WRENCH - analogue is about P1,300, a "high-tech" is nearly P4,000
15. PULLER GRIPPER - depending on size, P300 to 800 ang range, generic brands
16. TIMING LIGHT (FOR ENGINE) - depending on brand and pa-ek-ek it is between P2,000 to 10,000 - craftman yata yung brand na maganda
17. VISE GRIP (U.S. OR GERMAN) - depending on size and tip/nose design, it is about P200-P500
18. GATO MEDIUM - china about P2,000, other better brands about P3,000
19. ALLEN WRENCH (1 SET) U.S. OR GERMAN - metric o english?, about P1,000 yung good brands
20. SPRAY GUN - HVLP type (high volume, low pressure) is the best, small ones P800-1,000 bigger volume capacity can reach P15,000-20,000. HVLP type is a prefered type for environment issue (lesser misting that just pollute the environment) and tipid sa paint and pede ito kahit small (like 1/4-1/2HP) lang ang compressor. A compressor is about P5,000 to 7,000 na ang china na 1/2HP, other implements like pressure hose, water separator and pressure regulator is about P3,000 to P5,000
21. TOOL BOX - plastic is P150-P1,000 depeding on size, metal is P500-P2,000
Is the price just about right? I hope someone can give me an estimate.
IMO
so at P30,000 that is very cheap! my estimate is that all these will cost you nearly a P100,000 if you really want good brands that can last you a lifetime.
if you go mostly china or lesser known brands, probably near P50,000 pa rin yan.
