Results 1 to 7 of 7
TheOneThatIs
- 1,306
October 13th, 2007 01:58 PM #1Hi.
I sent my mechanic yesterday to go to Manila (Alonzo St.) to buy some tools. He returned and told me that the the whole list would cost more than 30T Php.
Here's the list:
1. CROCODILE JACK (5T)
2. ANGLE GRINDER (MAKITA) & IMPACT ELECTRIC DRILL (MAKITA)
3. SOCKET WRENCH SET (10-12 MM) U.S. OR GERMAN
4. DEEP SOCKET WRENCH (12-30 MM) U.S. OR GERMAN
5. STEEL STAND (1 SET) 4 PCS.
6. CROSS WRENCH H.D.
7. HAMMER BALL H.D.
8. PHILLIP SCREW SET & FLAT
9. COMBINATION BACK WRENCH H.D. (10-24 MM) U.S. OR GERMAN
10. PLIER & LONG NOSE
11. CHISEL (SINSIL) H.D.
12. VALVE LIFTER
13. PISTON RING GRIPPER
14. TORQUE WRENCH
15. PULLER GRIPPER
16. TIMING LIGHT (FOR ENGINE)
17. VISE GRIP (U.S. OR GERMAN)
18. GATO MEDIUM
19. ALLEN WRENCH (1 SET) U.S. OR GERMAN
20. SPRAY GUN
21. TOOL BOX
Is the price just about right? I hope someone can give me an estimate.
Thanks in advance.
October 13th, 2007 03:15 PM #2
If you want to see comparable prices here in the US (you mentioned US brands) go to Harbor Freight tools website. Great resource of tools.
Piston ring gripper, timing light, torque wrench, floor jack and others can be expensive, yes. The good jacks here in the US are around $80+ so 5000 is just right for a really good one.
October 13th, 2007 08:55 PM #3
sir,
try to scan sa yellow pages hardware section madami dun then fax your quotation form sa kanila para mas madali, in alonzo, try mo si IRIS COMMERCIAL or Hans Infinite Tools sa may tayuman
October 14th, 2007 02:17 PM #4
canvas ka muna...
dami hardware shop... alamin mo iyun brand and price para may comparison bago ka bumili...
Tsikot Member Rank 3
- Dec 2002
- 636
October 15th, 2007 02:01 AM #5Suggest you check Japanese tool brands like KTC, Tone, Koken. Different price ranges with KTC having the best reputation for quality.
Check with New Triumph hardware on CM Recto, Sta Cruz.
BANNED BANNED BANNED
- 3,790
October 15th, 2007 06:08 AM #6
October 18th, 2007 11:18 AM #7
Sa crocodile jack 5tons i presume,that is kinda heavy. Ff you want quality that would last Masada is good. MACHINEBANKS 7113751 look for Arianne.
Allen wrenches have different variation may tx-starbit, ribe, spline and the common hex. Sa Panda (7168361,7168362 Mr.Sy) they have a set that is just great. They have in stock just everything that a mechanic would need at a good price from the U.S, Japan, China. 340B Araneta ave QC.
Sa valve spring compressor i suggest you buy the non clamp so you can use it while the head is still bolted.
All the rest of your needs are available there, even vacuum and compression gauges and SS tools. Ang sarap tumingin. They have nice looking tool boxes and drawers that is just priced right.
Goodluck bro.Last edited by 4JGtootsie; October 18th, 2007 at 11:47 AM.
naalala kong bigla... you can also have your valve clearance checked... baka di na sya nagsasara ng...
