Results 1 to 9 of 9
- Apr 2006
- 40
May 9th, 2006 05:01 PM #1i have honda civiv esi 95 with 95th mileage.
how much does preventive maintenance costs at honda centers?
or is tune-up necessary?
thanks
May 9th, 2006 05:48 PM #2
oo nga...ako din gusto ko malaman. kahit estimate lang. sa akin kasi nasa 77,000 Kms
- Jan 1970
- 396
May 9th, 2006 08:40 PM #3what exactly do you mean by preventive maitenance? madaming preventive maitenance, from oil change, to timing belt change. and it doesnt have to be done in the casa, mahal dun. madami naman magagaling na independent shops jan.
napalitan na ba mga timing belts nyo?
Tsikot Member Rank 5
- Nov 2003
- 3,848
May 9th, 2006 11:29 PM #4pagawa nyo sa casa... mahihimatay kayo sa price. hehe!
80,000 km., 160,000 km. Preventive Maintenance Check
· Change Engine Oil and Filter · Replace Transmission Oil · Replace Engine Coolant · Replace Fuel Filter (Carburator and PGM-FI) · Inspect Tie Rod Ends, Steering Gearbox and Boots · Inspect Suspension Mounting Bolts · Inspect Exhaust System · Inspect Brake Lines and Connections · Inspect Front and Rear Brakes · Inspect Driveshaft Boots · Inspect Fuel Tank, Fuel Lines and Connections · Inspect Belt Tension and Conditions · Inspect Water Pump · Replace Timing Belt · Inspect Distributor Cap and Rotor · Inspect Valve Clearance · Replace Air Cleaner Element · Replace Spark Plugs · Inspect Ignition Timing and Idle Speed · Inspect Positive Crankcase Ventilation Valve · Replace Brake Fluid · Inspect All Fluid Levels (Clutch, Power Steering, Coolant, Windshield Washer) · Inspect Battery Electrolyte Level · Inspect Compressor Clutch and Joints · Inspect Condenser Of Dirts and Insects · Inspect Freon Gas Level (Check Sightglass For Bubbles) · Inspect Engine Cooling Lines and Connections · Inspect Steering Pump, Lines and Connections · Inspect Parking Brake Adjustment · Inspect Clutch Free Play · Rotate Tires (Check Conditions, Wear And Pressure)
10,000 km., 30,000 km., 50,000 km., 70,000 km., 90,000 km., 110,000 km., 130,000 km., 150,000 km., 170,000 km., 190,000 km. Preventive Maintenance Check
· Change Engine Oil and Filter · Inspect Tie Rod Ends, Steering Gearbox and Boots · Inspect Suspension Mounting Bolts · Inspect Exhaust System · Inspect Brake Lines and Connections · Inspect Front and Rear Brakes · Inspect Driveshaft Boots · Inspect Fuel Tank, Fuel Lines and Connections · Inspect Belt Tension and Conditions · Clean Air Cleaner Element · Clean Spark Plugs (Replace If Necessary) · Inspect Ignition Timing and Idle Speed · Inspect Brake Fluid Level · Inspect All Fluid Levels (Clutch, Power Steering, Coolant, Windshield Washer) · Inspect Battery Electrolyte Level · Inspect Compressor Clutch and Joints · Inspect Condenser Of Dirts and Insects · Inspect Freon Gas Level (Check Sightglass For Bubbles) · Inspect Engine Cooling Lines and Connections · Inspect Steering Pump, Lines and Connections · Inspect Clutch Free Play · Rotate Tires (Check Conditions, Wear And Pressure)
May 10th, 2006 12:03 PM #5
pero sa experience ng mga tsikoteer..
estimation lang po ang gusto namin malaman. let say less than 80000kms
May 10th, 2006 12:59 PM #6
Our last PM for our ESI was for 150tkm. The labor charge for this 150tkm tune-up/check-up was P756.25. From our experience, the total cost w/ VAT usually costs between 2.1-6.5k, depending on what parts you buy there during the PM. It's usually cheaper if you bring your own basic replacement items (air filter, oil, oil filter, spark plugs). Usually cheapest are the PMs done on odometer rdgs of 75k, 85k, 95k. Next the 70k, 90k, 110k. Next the 60k, 100k, 140k. Most expensive are the ones every 40k (at least for matic ESIs), the 80k, 120k, 160k, because of the matic transmission fluid change.
If you want, you can also call your nearest Honda dealer (just pa-connect to service dep't) to get a rough estimate of the expected PM/check-up for your ride.
Here's their link showing their tel #s.
http://www.hondaphil.com/dealerships...ation=fairview
May 10th, 2006 05:02 PM #7
nakapag-tanong ako sa honda pampanga.
ang estimate nila sa kotse ko is 14,000 pesos mura na ba yun? nasa 80,000km
May 10th, 2006 05:08 PM #8
ang sabi sa akin ni ping (mekaniko ng honda pampanga)
depende daw sa mileage...sabi ko 80,000kms
estimate niya 14,000 pesos...
tanong: paano kung umabot na ako ng 100,000kms tapos nakapag-PM na ako nuong 80,000kms
mas mahal pa din ba ang babayaran ko?
- Nov 2003
- 3,848
May 11th, 2006 12:48 AM #9if you follow everything in 80k inclusive of replacing the timing belt, etc then possible umabot ka ng ganyan. pero it's best to bring the car in for a check. who knows, baka naman all the parts for checking need to be replaced na. kung ganun di na uubra yung initial na estimate. kung andun na car mo tho, it can be checked on the spot and an estimate can be done right away.
feel free to pass by the shop if you need this done.
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Liquid tire sealant
