Results 1 to 10 of 18
- Feb 2003
- 4
August 2nd, 2004 12:43 PM #1guys need ur help medyo matagtag kotse corolla gli 95 pina check ko sa rapide weak daw springs and shocks kakapalit ko palang ng shock sa front mga 3 months ago matagtag ba talaga pag sira na spings pls advice im getting a set of springs kasi and a gas shock sa likod tnx
August 2nd, 2004 05:24 PM #2
Pag sira ang springs, one obvious sign is body height sag. Mas mababa sa same model. Di lahat ng springs ang matigas o matagtag pag ngalay na, yung iba naman sobrang maalon ang ride. Kahit na bagong palit ang shocks.
Gusto nyo bang matagtag na ride? Bakit gas type ang balak nyo ikabit sa likod?
- Feb 2003
- 4
August 2nd, 2004 06:03 PM #3sumasayad kasi sa gulong naka 15" ako mags 55 series na gulong kaya may lifter ako ngayon sabi kasi pag nag gas type daw ako ang palit coil springs sa likod di nako sayad. so pag sira na spring medyo maalon ride? tnx
August 2nd, 2004 06:30 PM #4
Aha, modified naman pala yan. Try the cheaper route first by testing it with new shocks at the rear. Then compare the ride handling and stiffness/comfort. Mahirap mag guesstimate thru web.
- Feb 2003
- 4
August 2nd, 2004 08:50 PM #7
Matigas talaga ang gas shocks. Sa akin ito ang kinabit ko, yung 4x4 ko parang sakay lowered. Pero aware naman ako of the ill effects. Hindi naman talaga matagtag on bumps, the real difference that I see is that it will follow the road surface especially yung depressions. So bump ups for me is pretty good, yung bump downs ang problem. The shocks will pull the body to the wheels. The body does not float as much as fluid shocks. Pero oks lang sa akin, alam ko naman ganyan ang magiging effect. Kasi dati sa mga cars naman nag gas din kami kapag lowered na. Plus side is less body roll and for me it dampens the big bumps better.
- Apr 2004
- 19
August 9th, 2004 11:15 AM #8i recently bought a 90 corolla xl. nkakabit gas shocks and bnew springs. ang tagtag! ganito b tlaga ang gas shocks? parang nka lowered ng ilang putol.
advise naman po what should i do para maalis ang tagtag.
August 9th, 2004 11:22 AM #9
mas firm talaga ang gas shocks pare. you can go the fluid shocks route if wala ka naman planong mag lower ng kotse para maging mas soft ang ride mo.
August 9th, 2004 01:05 PM #10
Bakit yung 91 corolla ko bagong palit din yung shock sa unahan fluid type sya at KYB ang brand bakit matagtag pa din?
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
