Results 1 to 20 of 25
    just wanna make sure mga bos, whenever one replaces the timing belt of his ride, automatically the timing belt tensioner is also replaced, right ? what other parts are also essentially due for replacement once the timing belt is up for a change?
    All the parts I listed are the necessary parts to be replaced as per Suzuki's recommendation.
    Some of the parts are not really due for replacement, but since the engine is apart already, it makes sense to replace at the same time to lessen labor costs.
    Yes, it's a must to get a new tensioner. The water pump and crank/cam seals are also a good idea since you won't be visiting that part of the engine for the next ten years or so.
    Kala ko timing chain lahat ang Zuk sa 2007 Grand Vitara lang pala.
how do you know when your timming belt is broken?
