Results 1 to 3 of 3
- May 2010
- 3
July 18th, 2011 03:17 PM #1Mga boss, patulong naman po sa problem ko sa Mitsubishi Adventure/2006/GLX/Diesel. I notice na may vibrating sound siya habang naka-idle. nagtitrigger yung "vibrating sound" everytime na tumunog ng "click" yung aircon. Nawawala din nman ito after mga 5 to 8 seconds. Then magsisimula na nman ulit after tumunog ng "click" yung aircon.
Nawawala yung vibrating sound once na I turn off the aircon. Nawawala din itong vibrating sound if I will step on the gas pedal. Any suggestion po before dalahin ko sa mechanic? Thanks in advance po sa mga inputs galing sa inyo.
Bembol
- Oct 2009
- 72
July 24th, 2011 06:10 PM #2Check the aircon compressor for looseness in its bracket, also check the exhaust pipe, especially near the connection between the exhaust manifold and exhaust pipe (also called exhaust neck), this is prone to cracking with would lead into a rattling sound when idling.
July 24th, 2011 06:22 PM #3
aircon is an additional load sa engine. mukhang mababa ang menor kapag naka-on ang air-con. have it adjusted.
Hyundai Santa Fe GLS 2024
Tsikot Hyundai Registry
