Results 1 to 5 of 5
October 14th, 2007 02:57 PM #1
i just rececently had my windshield replaced, and no im having a minor problem with my rear view mirror... how do i stick it up in there? what's the best type of adhesive should i use to keep the darn thing from falling off? i tried using 3M doule sided tape... unfortunately, it's not strong enough to handle the mirror's weight.. please help.. hirap mag drive ng walang rear view mirror eh... thanks in advance...
October 14th, 2007 02:58 PM #2
i just recently had my windshield replaced, and now im having a minor problem with my rear view mirror... how do i stick it up in there? what's the best type of adhesive that i should use to keep the darn thing from falling off? i tried using 3M double sided tape... unfortunately, it's not strong enough to handle the mirror's weight.. ano po ba yung ginagamit sa factory or sa casa for this purpose? please help.. hirap mag drive ng walang rear view mirror eh... thanks in advance...
October 14th, 2007 04:59 PM #3
30 tape would have been my first suggestion... are you using the automotive grade tape?
October 14th, 2007 11:04 PM #4
auto glass shops have this sticky black sealant they use for windshield installation. they also use it to stick the rear view mirror on the windshield. it should cost you P50.00 if you bring it to them. be sure that the windshield and the base of the mirror is clean when securing it in place. detach the rear view mirror from its base prior to installation so as not to put weight while it is still not cured. when i did mine, i cleaned the windshield portion to attach the mirror and base of the mirror with denatured alcohol. wait a few minutes for it dry and applied sealant on the base of the mirror and stick it to the windshield. held it in place for 2 minutes and let go. waited 3 days for it dry and cure. finally, i attached the mirror to the base. 3 months passed and still in tact. another solution which would cost you some money is to order the real adhesive on amazon.com. it is called rear view mirror adhesive kit.
October 15th, 2007 06:37 PM #5
