Results 21 to 30 of 54
December 25th, 2005 10:56 PM #21
From the CRV owner's manual:
"To close the bonnet,... Lower the bonnet to about 30 cm (a foot) above the fender, then let it drop.
December 25th, 2005 11:21 PM #22
drop from a considerable and non-damaging height.
you could feel whether the drop was excessive or not.
December 26th, 2005 02:16 AM #23
heheheh...ako parehas kong ginagawa...depende sa trip ko...pero madalas method 2, naka state ito sa manual...pero pag gabi ako lumalabas, i use method 1...para tahimik (nakakagising kasi sa kapitbahay)...pero, i take caution pag ginagawa ko yung #1 by applying pressure kung asan yung contours nung hood (yung parang umbok sa both sides [left and right], sana maintindihan mo kung anu yung umbok! heheh)...i do this to avoid accindental denting since yun yung strongest part ng hood. so far, wala naman dents yung hood ko.
December 26th, 2005 02:51 AM #24
depends on my mood or the area. kapag masyado tahimik like gabi na, method 1 tapos don sa may part nearest sa edge ko pinupush para matigas.
- 10,620
December 26th, 2005 05:03 PM #26drop the hood also, dati nung bata ako na dent ko hood ng brand new car ng tito ko...
December 26th, 2005 05:09 PM #28
Method #1 can be also be used if the hood has area that can pressed without denting it (chrome trim, or emblem- ie. EG Civics).
December 27th, 2005 12:18 AM #29
i drop it as well from about 4-6 inches. the hood's weight will help it close when dropped. :D
method 1 is usually applicable for CF hoods
i would expect something like this, if the authorizing authority did not have a clear idea of their...
Suzuki Fronx
