Results 21 to 40 of 54
    May 2005
    From the CRV owner's manual:
    "To close the bonnet,... Lower the bonnet to about 30 cm (a foot) above the fender, then let it drop.
    Jan 2003
    drop from a considerable and non-damaging height. you could feel whether the drop was excessive or not.
    Oct 2005
    heheheh...ako parehas kong ginagawa...depende sa trip ko...pero madalas method 2, naka state ito sa manual...pero pag gabi ako lumalabas, i use method 1...para tahimik (nakakagising kasi sa kapitbahay)...pero, i take caution pag ginagawa ko yung #1 by applying pressure kung asan yung contours nung hood (yung parang umbok sa both sides [left and right], sana maintindihan mo kung anu yung umbok! heheh)...i do this to avoid accindental denting since yun yung strongest part ng hood. so far, wala naman dents yung hood ko.
    depends on my mood or the area. kapag masyado tahimik like gabi na, method 1 tapos don sa may part nearest sa edge ko pinupush para matigas.
    Aug 2005
    i just drop the hood, i dont want dents on my hood
    drop the hood also, dati nung bata ako na dent ko hood ng brand new car ng tito ko...
    drop it.
    May 2005
    Method #1 can be also be used if the hood has area that can pressed without denting it (chrome trim, or emblem- ie. EG Civics).
    i drop it as well from about 4-6 inches. the hood's weight will help it close when dropped. :D
    method 1 is usually applicable for CF hoods
    dropping din ako....
    me too, dropping
    droppin' da hood iz mah istayl
    yun sabi sa casa, malambot daw kasi hood ng xwinds.
    Feb 2005
    i drop it too! i like the sound it makes when dropped. hehehe
    sa mga kaha ngayon, drop it from a considerable and non-damaging height. you could feel whether the drop was excessive or not. pero sa mga older models (79 below) kahit tapakan pwede
    Pag kase push minsan sa lakas nagkakadent hehe
    "Drop it like it's Hot" :D
    i use the method #1..syet..don pala galing ung dent ko..:D
    Oct 2004
    1 &2
    1 kay waqs, dun sa pinakadulo ng hood ko dinidiinan para walang dent
    2 kay quiksie, kasi mataas height niya para gawin ko yun 1 kaya drop nalang
    i drop it like it's hot. :D
    Sep 2004
    I always drop the hood. Since I can be conscious of the neighbors at night, I only open the hood during the daytime, para kahit maingay and pagsara, ok lang.
How to close the hood properly
