Results 1 to 10 of 10
- Mar 2003
- 2
March 13th, 2003 01:32 PM #1Anyone knows where I can find a computer replacement for Honda City '99 model, please let me know. Thanks.
Also, if there are any auto shops that can fix/replace computer box for Honda City '99 model.
Again, Thanks,
erigby
- 290
- Mar 2003
- 2
March 13th, 2003 04:28 PM #3hindi naman siya nabaha. one time bigla na lang umilaw ang malfunction indicator tapos
naging unstable na pag-idle (tumataas ang RPM). Dinala namin sa casa at ang sabi eh sira daw ang RACB (rotary air control valve) at ECU (computer). Sobrang mahal! Hindi ko pa pinapagalaw sa casa.
Me alam ka bang puedeng mapg-gawang iba ?
November 17th, 2004 04:20 PM #4
Hi guys,
meron problem friend ko sa honda city 2000 type-Z 1.3 .. help naman po..thanks
eto po yung kwento nya..
Kapag pinasok mo yung key, normally yung engine indicator eh iilaw tapos mawawala na, kaso inde namamatay yung indicator ko.., so pag-start ko ng engine, ayaw nya mag-start unless mag-step ka sa gas... tapos kapag nabitawan mo yung gas mamatay na ulit yung engine o kaya pag nag-down gear ka na habang tumatakbo ka eh mamatay na din yung engine..
Diagnosis of Honda Makati: problem daw sa rotary air control valve and repair ecu
any other opinions?
mga 19K yung ECU sa casa daw
thanks
November 17th, 2004 07:59 PM #5
Hello erigby & Revogsx
please visit
www.hondaclub.com.ph/forums
there are a lot of gurus there that can help
have you tried resetting your ECU? remove the negative battery terminal for 5 mins then re-install.
hindi ko sure kung pwede mga surplus ECU galing japan sa city.
November 17th, 2004 08:16 PM #6
40K daw pala yung ECU sa casa, 10K kung ire-repair yung ECU
9K dun yung RACV
wala pa yata labor cost nito..
November 17th, 2004 08:22 PM #7
Try mo sa GreaseBee sa Ortigas Extension (lagpas ng junction), nagrerepair sila ng ECU...
November 17th, 2004 11:22 PM #8
Get a second opinion from another casa, our car was previously diagnosed with the same problem. Had them check again properly since the ECUs are not that easily damaged unless they are submerged in water. It turns out that the technician did not plug the ECU firmly. Most ECUs are built to last a long time.
November 18th, 2004 12:13 AM #9Originally posted by revoGSX
November 19th, 2004 01:24 PM #10
salamat sa mga reply po ninyo
paano nasisira ang Air Control Valve? dahil ba madumi na air filter? common problem ba ito sa honda? o lahat ng car meron nito?
Daming issue ng SU7:grin:
Xiaomi E-Car
