Results 1 to 8 of 8
- Sep 2009
- 45
November 8th, 2009 09:57 AM #1yung auto ko po kasi na honda vtec 98 model AT.
yung problema po kasi niya hirap po siya umaandar ng mabilis..lalo na pag nasa hanging ako sobra bagal auto ko...then pag nasa nlex naman ako yung takbo ko around 80 lang halos hindi siya nag sshift na stock lang siya sa ganun pag nasa nlex ako ang tendency ayun mag oover heat siya ngayun,,pina check ko siya sabi sakin palitan kona daw yung transmission ko.,,what do you think the best ko gawin para sa auto ko?..sana po matulungan nyo ako,,thanks!
November 8th, 2009 10:15 AM #2
Pa check mo rin sa ibang mechanic for second opinion . Hindi nag shift sa higher kaya ka nag overheat . Pag rekta ka na nasa ilan ang RPM reading mo .
- Sep 2009
- 45
November 8th, 2009 10:30 AM #3around 40 to 60 lang mga ganun..
napa change oil,tune up and change fuel filter kona ganun pa din cia..
hirap na kasi ako mag tiwala sa ibang mechaniko...
gusto ko sana dalin sa casa kaso naku po ubos pera ko dun malamang...
November 8th, 2009 12:16 PM #4
oiknez,
have your transmission oil level checked. maybe your transaxle oil filter is clogged. maybe your brakes are dragging. please describe the conditions when the symptoms appear. time from start up, speed, temperature gauge indication, engine rpm vs. vehicle speed. your transaxle oil change is due around 30,00 miles, your brake fluid of DOT 3 is due to be flushed and replaced every two years. follow your owner's manual service intervals for extreme driving conditions
jick
- Oct 2009
- 12
November 8th, 2009 07:23 PM #5Bro focus on the transmission.
A/T transmissionbs depend so much on the oil presures at the transmission casing. some xmissions have a separate computer box controlling it. Your mechanic must upgrade himself to A/T servicing. Its not as easy as the M/Ts. Too technical and complicated... You might as well change transmission for lesser head aches...
Ed
THE AUTO SPECIALIST
- Mar 2006
- 607
November 8th, 2009 10:41 PM #6kailan lang may ginawa ako honda 98 din tranny ang sira
check mo fluid level muna at kuha ka ng second opinion sa mga tranny shops bago gawin
- Oct 2009
- 12
November 9th, 2009 07:01 PM #7[Bro,
Hwag nang hintayin na abutin ka sa Hihgway at ma-towing ka pa. Your main problem is the transmission.
A/Ts have a stack of clutch assymbly. kung worn out na yun, di na maka hatak ng normal. it is soaked in oil kaya wala kang ma-amoy na sunog. If you drain your transmission oil, you will see a dark.... almost coffee, thick oil. this means your clutch disks have worn out...
A/T transmission clutch has a similar clutch with that of an ordinary motor cycle... di mo maamoy ang nasusunog na clutch...
Find your transmission model from surplus stores kung nag-titipid and change the whole thing. Change the whole thing with BNew kung may enough funds. Repairing it may cost almost the same... and worse di maibalik sa tama...
Ed
quote=oiknez;1359262]yung auto ko po kasi na honda vtec 98 model AT.
yung problema po kasi niya hirap po siya umaandar ng mabilis..lalo na pag nasa hanging ako sobra bagal auto ko...then pag nasa nlex naman ako yung takbo ko around 80 lang halos hindi siya nag sshift na stock lang siya sa ganun pag nasa nlex ako ang tendency ayun mag oover heat siya ngayun,,pina check ko siya sabi sakin palitan kona daw yung transmission ko.,,what do you think the best ko gawin para sa auto ko?..sana po matulungan nyo ako,,thanks![/quote]
- Sep 2009
- 45
November 10th, 2009 07:10 AM #8I see.. sana maayos na prob. ng auto ko..
biruuin nyo u speed ko nasa 1 and 2 lang hindi cia nag shift,then hirap na..
thanks sa lahat ng advice nyo po..It's give me more idea para alam ko gagawin ko..
Xiaomi E-Car
