Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
    Aug 2004
    edit
    Sep 2004
    wala nang dapat pag-usapan dito. 1st gear is low gear. ang 5th, 6th, 7th gears ang high gears. standard na sa car manufacturers ang terms na to. just look at the a/t cars. L1 stands for low gear 1st. L2 stands for low gear 2nd.
    Jun 2004
    sa technical ata:
    1st gear=high gear
    5th gear=lowgear
    the more higher ung gear d more mababa ang topspeed, d more lower yung gear ratio mataas topspeed
    parang ganito
    1stgear 2.842:1
    5thgear 0.712:1...>>hehe
    ano ba talaga kuya????
    hehehehe.....
    Ahehe... sabi ko na nga bat tuliro pa rin ako nung pinaliwanag ko kanina...
    Basic rule:
    1. Higher numerical number is lower gear. Raises your rpm at a certain speed. Sample: 1st gear = 4.556; 2nd gear = 2.625
    2. Lower numerical number is higher gear. Lowers engine rpm on high gear or top gear. Sample: 4th gear = 1.000; 5th gear = 0.836
    You will also have to consider your final gear ratio, either for top speed lower numerical number, vice versa.
High or Low Gear
