Results 1 to 10 of 10
December 26th, 2006 07:28 AM #1
hello Good Morning mga sirs at mams.nag drive kasi ako kahapon sa beach.then i actually heard a sound na tukutok ot toktoktok.
. simultaneous yung sound from the house to the beach hanngang makauwi ako kaya dinahandahan kolang yung patakbo nd kasi me cgurado
bka may bumigay.... indi koalam kung sa bandang manibela basta nasa hood lang xia... have any 1 experience the same problem i got ?? hope i gather informative replies Thanks and More POwer
- Nov 2006
- 299
December 26th, 2006 12:13 PM #3
Corolla 97 Model... wala naman pong accident..... b4 that sound occur...i guess parang sa engine nanggagaling ung tukotok sounds..
Tsikot Member Rank 5
- Nov 2003
- 3,849
- Nov 2006
- 299
December 26th, 2006 04:30 PM #5
December 27th, 2006 06:15 PM #6
The day na mismong ginamit kopo ung car... pag tumatakbo lang po xia dun po tumutunog the more na mabilis ako tumakbo the more na mabilis din ung sounds....
- Nov 2003
- 3,849
December 28th, 2006 10:14 PM #7have it diagnosed by a mechanic asap. don't just leave it making noise.
December 29th, 2006 02:24 PM #9
heto na po mga pare. jinack ko kasi ugn car kahapon and try ko paandarin nakita ng kapatid ko na sa may bandanf front-left parang may maluwag.tinaggal ko ung tire sa left-front andnapansin ko dunsa may bandang disc brake nya at sa lalim ng joint pagtinutulak ko paloob maluwag xia....ok paman ang ball joint.bagung bagu payun wat could be the cause? para ma paaysu kona agad baka delikado e2 m ma car crash pa tayu
December 29th, 2006 04:30 PM #10
Dalin mo na agad sa talyer yan bago pa lumalala. suggestion lang po.
i have a theory, if the oil filter is not primed (filed up prior to installation), the initial...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
