Results 1 to 20 of 34
    Sep 2006
    Plan ko po magpalit ng "CV joint" assembly and if incase pati "Axel Shaft" on my Corolla 90.
    1. How much po ba yung replacement of the two items i've mentioned? Any idea po?
    2. Is it possible to replace only one side, for instance sa right side?
    3. What brand for replacement is best in quality, durability?
    4. How much po kaya aabutin on Labor?
    Right Side, since dun po yung may tumutunog pag malubak(Tipong mababaklas na yung buong sasakyan sa ingay ng manubela) Example po, pag dumaan ako coming from San Juan going to Araneta Ave. Pagpasok na pagpasok po kase ng A.Ave mejo malubak ayun, Nagpproduce na ingay Nanginginig na manubela and sound under the hood start to roar.
    But I was wondering kase na pagnaka aspalto yung kalsada and my mga lubak, hindi naman po nagpproduce ng sound sa manubela.
    Salamat po in advance
    Apr 2005
    replacement c.v.joint is 1850 per piece, nkn brand. labor 450/pc. i would recommend replacing both sides to save downtime.
    based on your symptoms mentioned, baka balljoints lang yan. CVJ sa pagliko tumutunog.
    replacement balljoint 650/pc.
    i just had my CVJ's replaced. my problem now is lumalagutok pa rin kahit going straight lang basta arangkada. sabi mekaniko, mawawala daw yun after some time. until lumapat mabuti new CVJs. sana nga.
    un sa akin cost almost 4thou both sides last monday lang....replacement CV joint + labor....kaya lang may maingay pag-mabagal pero pagmabilis naman nawawala...babalik ko nga para makita ulit .....
    Sep 2006
    Thanks sa mga reply. anyway, nagtanong ako sa my Celica along Araneta. Price is between that range. pero taga sa labor yung katabing BIG name shop. almost 1Thou+.
    Apr 2005
    it's been over a month now, lumalagutok pa rin new cv joints car ko when accelerating/arangkada. alin kaya problem, yung pagkagawa or ung new replacement cvj's?
    Jul 2003
    yung lagutok ay maaaring naggagaling sa inner cv joints. maaari kasing my play na yung "spline" na nakakabit sa transmission. napalitan mo din ba ang inner cv joint, both sides?
    sir may possibility din na sira rubber ng engine support pag may lagutok sa arangkada
    May 2007
    Kung nagawa na nila noon ay may lagutok pa, maaring careless ang mechanico mong gumawa. Generally, e confirm mo ang damage kung yong balljoint lang ang sira o kaya may vent na ang halfshaft mo o di kaya hindi nilubricate ng maayos. Have them also check both, inner and outer joint.
    Sep 2005
    sakin may lagutok na pag naliko...pwede pa bang i-repacked yung CVJs ko?
    May 2007
    Quote Originally Posted by puroy View Post
    Better replace it than used the same one. CV joint is one of the most crucial mechanical parts of your car so its a lot wiser to replace besides may tama na yan. Remember, your mechanic must know the torque of your CV joint when he reassembled back in, too tight can damage the halfshaft, too loose will damage it too. If your not sure about your mechanic if he knows about this find out the torque lbs., of your car.
    Sep 2005
    Quote Originally Posted by v6dreamer View Post
    thanks. question, ano pong brand maganda ipalit sa CVJ and magkano dapat budget?
    Sir, can you suggest where I can buy a CV Joint for a nissan pulsar model?as of now wala pako nabibili, it's almost 2 weeks na. Thank you.
    May 2007
    Quote Originally Posted by alord_27 View Post
    Pa rebuilt mo nalang mas mura. Boot lang ang papalitan kung hindi pa sira ang bering. Lilinisin nilang maigi to remove contaminant at irepack nilang mabuti ng grasa at palitan ng bagong boot.
    Nov 2003
    some cv joints can be repacked pero if you wanna play it safe have them replaced na.
    Apr 2005
    update: turned out 1 inner cvj got loose. nire-pack lang lahat. it's been ok since fri.
    Jan 2008
    sir newbie lang po, question lang kasi ganun din problema ko lumalagotok yung front wheel ko at the right side, pero di naman siya tumutunog pag lumiliko ako. minsan lang pag mejo uneven yung daan at sabi ng isang mech ko CV daw dahil punit daw yung boots at puno na ng grasa yung labas niya, CV kaya yun or may iba pang possiblities na mga bushing bushing lang, kasi kakapalit ko lang ng shocks bushing at ball joints
    Sep 2005
    sir, saan mo pinagawa and magkano damage?
    Aug 2007
    yun ride ko meron din maingay/lumalagutok kapag dumaan sa humps kahit mabagal na ang approach sa humps; tsaka sa mga potholes kahit mnababaw.
    ang diagnosis ng mekaniko ay trailing arm bushing.
    hayun pinasilip ko at confirmed na trailing arm bushing nga; have cracks already. so, i had both bushings (left/right) kasi the other side have marks na rin...
    now, wala na ingay/lagutok kahit lubak, humps at straight pa ang dadaanan.
Replacing C.V. Joint
