Results 1 to 10 of 54
December 24th, 2005 06:16 PM #1
Which is the correct way of closing a vehicle's hood, by
1) Lowering the hood slowly until the hook will latch on and press down to lock.
or
2) From a height of 300mm or less drop the hood. This would lock the hood already.
I use method#1 but when I use this method, I noticed the portion of the hood where I press down on to lock, has some small dents.
I'am thinking maybe if I can use method#2 to avoid the dents, but I dont know if I drop the hood like that, it might destroy the lock(hook)mechanism inside.
So, which method does the least or no damage at all? I dont want the dents neither do I want to inadvertently destroy the hood locking mechanism.
Pls help.
December 24th, 2005 06:29 PM #2
the owners manual of my car suggests raising it about a foot then dropping it
December 24th, 2005 06:29 PM #3
me i drop it from a level of around 4-6 inches coz method 1 doesn't work for me
BANNED BANNED BANNED
- 3,790
December 24th, 2005 07:24 PM #4i drop my hood (roughly between 5-12 inches)...the lock is sturdy, you can't break it. Dati I use number 1 method, I also see dents...so I changed style
- Jun 2004
- 1,311
December 24th, 2005 09:16 PM #7
RTFM
with some cars the manual suggests dropping. with others pushing down with the palm is suggested.
probably depends on the design of the latches and reinforcements
December 24th, 2005 09:33 PM #8
what i do is leave at least around a foot tapos bibitawan kona and let it lock by itself
December 24th, 2005 09:59 PM #9
Never press on it... futresang ineng... I have dents on my hood already because I'm not the only driver. (okay, I'll admit to causing just one of them :lol: )... automotive sheet metal is pretty soft in the area around the latch. I always drop it about 1 foot. Scary, but it works.
December 24th, 2005 10:27 PM #101) Lowering the hood slowly until the hook will latch on and press down to lock.
probably safe to buy next yr. two yrs enough time to iron out the kinks. these cars are quite...
VinFast VF 3
