Results 1 to 5 of 5
- Feb 2009
- 3
February 20th, 2009 06:40 AM #1Hello peeps, baka po meron kayo na marerecommend na shop pede pagawa ung windows ng car bumababa na kasi tapos di na nagfa-function ung handle for window. Thanks po in advance.
- Feb 2009
- 3
February 20th, 2009 10:57 AM #3
Aggravating to fix, but not expensive.
The problem is that a little plastic part has slipped off or broken, letting the window become disconnected from the crank rod. Pull the door panel, and watch as the lever is moved. You should see exactly where the part is broken.....you may have to feel around at the bottom of the door to find it. The dealer should be able to get the part for you unless it's something available at a parts house. If you loved working on a car you would be able to fix this. Its not hard to understand the problem once you remove the door panel to see exactly the cause. Its a small job, but kind of tough....not much space.
- Feb 2009
- 3
February 21st, 2009 04:18 AM #5
Xiaomi E-Car
