Results 1 to 20 of 30
    Good Day guys
    Here's the scenario. i have a '99 Nissan GTS. naka Airbag ang problem ko sira na busina ko, mismo sa loob ng manubela. pinacheck ko sabi CASA lang mkakagawa nun, i inquire sa nissan casa, d nadaw nagagwaw, bili nadaw ng bago worth 9K (lintek busina lang problema ko) kasi daw yung adaptor electronic type daw. d nagagawa pag sira Bago ndaw.
    is there a way para gumana busina ko. without costing that much.
    please help.
    up ko lang po
    Sep 2004
    You can try to bypass the horn mechanism inside the steering wheel assembly. External horn button na mounted elsewhere. Parang yung mga nasa ibang PUJ.
    Sobra naman yung talyer na yon at kasa. Ang alam ko, you just have to disconnect the battery terminals para di ma-activate yung airbag sensors by accident, so you can safely disassemble yung steering wheel panel. Tapos pa- bypass mo sa auto electrician, gaya nung ginawa sa akin (pero wala akong airbag ha?)
    Baka naman horn relay lang problema?
    d horn relay eh.
    the adaptor itself na ang problema eh.
    is there any other way, meron bang parang ganun adaptor same sa nissan airbag adaptor.
    Nov 2006
    ingat ka dyan,di basta basta na problema yan kasi palagay ko parang iisa ang connector ng air bag at ng busina at mas maganda maliban sa idisconnect mo yung battery hanapin mo rin yung air bag fuse para sigurado at wait ka ng at least 15 minutes to discharge the stored voltage sa sri system.panigurado lang.ingat ka.
    oo nga eh.
    busina na, laki na ng gastos.
    is there any other way na ibang adaptor kht na manubela iba palit.
    someone mentioned na MOMO adaptor, but wala pako nababasa na pwde.
HELP!!! Nissan Airbag
