Results 21 to 30 of 30
August 10th, 2007 10:52 AM #21
Yup tama na kailangan ng adapter sa steering wheel.
It's like replacing it with a Momo steering wheel.
The adapter will vary depending sa model/brand ng car.
- Nov 2006
- 299
August 10th, 2007 12:45 PM #22teka ano ba ang itsura ng sinasabi nilang adaptor,baka connector at hindi adaptor.anyway baka pwede mo na lang gayahin ang ginawa ni wildthing or itry mo sa ibang shop baka marepair pa yan at low cost masave pa yung air bag mo.
August 10th, 2007 09:02 PM #23
Nung nagkaproblema ako sa busina sa MB100, nadiagnose ni Mang Mario na naupod lang yung contact that bridges the steering wheel to the steering column metal ring. I can see that the rod does not reach the ring anymore when I looked at the gap between the wheel and the column closely. Kailangan lang daw pondohan ng bakal para mag-abot ulit.
It worked! I'm not sure what part broke in the threadstarter's case. Pictures would be nice.
August 11th, 2007 07:30 AM #24
I think yung sinasabi mo na adaptor ay yung clock springs or apiral springs. Ito ang karaniwang sira pag walang busina ang mga di airbag na sasakyan. Kadalasan nababasag yung inner parts nito or yung springs. Pinakamadaling way mo para magkaroon ka ng busina ipabypass mo na lang muna ung horn switch habang nagiipon ng pambili ng bagong parts. Mas safe pag may airbag di ba? Hindi ko sure kung pede yung mga replacement na steering wheel kasi kung mapapansin mo parang mas malaki yung pinakabibig ng steering trim ng di airbag. Saka malamang na iilaw ung airbag light mo sa dashboard at baka magkaproblema ka pa sa SRS system since it was connected in the computer. Here's the example pics of clock springs napakamahal talaga nyan
BANNED BANNED BANNED
- 3,790
- Nov 2006
- 299
August 11th, 2007 10:38 AM #26yan na nga ang sabi ko connector (clock spring electrical connector) at hindi adaptor.ito ay hindi repairable at replacement na ang kailangan dito.
advice ko lang sa iyo kaibigan,kung ako sa iyo,di baleng magsakripisyo ako ng 9k para palitan yang parts na yan ng bago kesa isakripisyo mo buhay mo incase magkaroon ng accident,o di kayay 10x pa ang magagastos mo panghospital kung sakaling mabuhay ka.wag naman sana.kaya palitan mo na lang total para sa kabutihan mo rin naman yan.siguraduhin mo lang na casa ang gagawa at seguraduhin mo rin na replace at hindi repair
August 11th, 2007 11:36 AM #27
up im aware na importante ang safety, but for the mean time, medyo super kapos eh. kaya naghahanap ako ng other way.
my nabibili bang clock spring electrical connector na sur[plus? please advise thanks
- Nov 2006
- 299
August 11th, 2007 12:38 PM #28itry mo daw iturn ang ignition key from off to run position at bantayan mo ang air bag readiness light kung ito ay mag on ng sandali at mawawala ng ilang segundo lang (2-5 seconds)pero kung ang light ay mag stay on o mag flash o talagang walang ilaw from off to run position,ibig sabihin ay nagmalfunction ang air bag system.isa na dyan ang clock spring na sinasabing sira.pero kung nag on ang ilaw ng sandali at nawawala,ibig sabihin ay hindi sira ang clock spring.baka busina lang talaga ang problema (horn,horn fuse,horn relay).itry mo daw icheck ang circuit ng busina.
August 11th, 2007 02:14 PM #29
sir, they already check. sira talaga yung connector (clock spring electrical connector). and tinanggal nadin nila muna yung fuse for the airbag para ndi mag engage.
busted nadaw yung connector. the mechanism itself na ang sira kaya dapat talagang palitan.
possible kaya ang bypass?
thanks
August 11th, 2007 11:44 PM #30
Pwede naman bypass, disconnect mo lang yung wire ng horns mo. Mag-line ka ng bagong power source (direct from battery) and use a relay just like what is done when upgrading horns. But instead of the OEM switch to trigger the horns, wire a new switch as well. The concept of the wiring is not that different from that of wiring an additional set of foglamps or other electrical accessories. Then use a switch that is only activated while you are pressing on it [not those lamp switches that can be left on].
Horn switches not on the steering wheel are not new anyways. Some Peugeots and Land Rovers have them on the end of the signal lamp control stalk. Same thing with most buses.
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
