Originally Posted by
wildthing
sayang sana hindi ka muna sana bumili ng ecu....i have a gut feel...it's the fuel system.
I believe that the fuel from the tank is not supplying fuel properly sa engine. I believe you have to check if the tank have been contaminated with water - drain the tank, purge the fuel line with air, replace the fuel filter and finally test the pump if the pressure and amount of fuel that it pumps is still correct (as per specs of an ESI).
Kung dumaan ka sa baha, it is possible water sipped in and damaged the fuel delivery system somehow.
that's my best guess.
