Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    I'm going to have the underchassis repaired. Here is the quotation for parts. Though it's still not certain whether all the parts on the list will be used, the parts store still listed them down 'just in case'.
    Upper balljoint 650x2
    Lower balljoint 850x2
    Pitman arm 1200x1
    Idler arm 1350x1
    Tie rod 450x2
    Shocks (KYB Gas non-adjustable in case the adjustable ones are shot already) 1100x4
    Ok na ba ang prices na ito? Pareho po ba ang pang-ilalim ng GEN II sa GEN II.5? I'm pretty sure they are but I just want confirmation. Wala kasi yung unit dito ngayon.
    How much do I expect to pay in labor (shadetree mechanic)?
    How much does it cost to realign afterwards?
    Salamat po
    Jan 2003
    Try to ask ZEE at Aurora Blvd. Was supposed to have my shocks refilled there but ok pa at the time so those parts you listed lang talaga ginawa. Rey is there Paj expert. He's their all-around "consultant."
    Btw, for sure palit ka bushings din nyan.
    Oteps, there are four tie rods to a Pajero I think most suspension parts are the same for the 2 and 2.5. Pansin ko lang na iba is the stab bar and stab bar links.
    Alignment sa servitek mga 1200-1500 kasi definitely may camber correction involved.
    Make sure you go to a friendly mechanic para one-time-take-all ang price kasi kung sa regular mechanic/casa, per part ang singil ng labor.
    Meron ako alam kaya lang dito sa pateros.... medyo malayo.
    Good as new na yan pagkatapos.
    BTW, naka Gen2.5 ka na pala! Congrats!
    It's the office vehicle and it would be better to have any faulty parts replaced as opposed to 'repaired'.
    I also do not want to subject the stock adjustable shocks to disassembly if it will lose adjustability anyway. If the shocks are found faulty, I will just take them home in a box.
    My '96 daily driver has had no bushings replaced since we got it. Wala naman problema sa suspension (except for the rear sway bar bushings). Anong bushings ba iyang 'sure' na papalitan? Thanks. The FM is a 2001 model if I'm not mistaken.
    PK,
    Nilista lang naman ang Tierods (mali pa naisulat sa listahan!). Magkaiba kasi yung mechanic at yung parts store.
    Btw, kay Mang Dick (yung in-house ni GlennSter) ko sana ipapagawa once the budget is approved. I guess he's friendly enough. hehe.
    Ayus! Nakakatawa kasi sa Motorix, parang casa na rin sumingil kaya di na ako dun nagpapagawa. Imagine, separate ang singil ng tie rod dis/assembly sa pitman and idler disassembly/assembly. Eh kung iisipin mo, kelangan mo naman tanggalin yung tie rods to get to the arms?! (And so on)
    As if naman ikakabit nila uli yung tie rods before nila babaklasin yung pitman/idler.
    I'll go through the same process within the year din siguro. Mabilis makasira ng tie rods ang 20"-45 series hehe.
    Oh well....
    Sep 2005
    Quote Originally Posted by OTEP
    Pitman arm 1200x1
    Idler arm 1350x1
    Tie rod 450x2
    Salamat po
    sir,
    suggest ko lang po go for orig 555 brand. hwag dre**
    mas matibay 555
    shocks around 800 lang yata... kyb gas...
    Sir banaweonline,
    Three Five (555) po ang gamit ko. I don't use Dreco for the underchassis bits. Medyo takot ako dun.
    otep,
    naask mo sa a1 motorcraft? baka masmura sila? not sure....is there such a thing as kyb shocks for 2inlift na pajero?
    Mas mahal ang parts sa Motorcraft. Ganun naman ata talaga kung sa talyer ka bibili instead of the parts store. Convenience kasi.
    May mga longer na KYB, ewan ko lang if meron locally.
    Quote Originally Posted by carnovice
    Just curious, magkano inabot lahat and ano exactly pinalitan. Thanks!
    Mar 2003
    PK how would you know kung sira na tie rods? pitman and idler lang kasi alam ko icheck.
    bolahin mo lang si mang dick..one of the nicest guy ive ever met. no bull.
    otep,
    if u want u go buy the parts and have motorcraft install it for u. i did that once na din and ok lang with them, atleast i know wat gawa nila. u could also go there and ask them what sira na parts mo then you could go n buy it urself.
    er, olats pa ako on what those parts are...anyone got pics on what they all look like and where they're connected? hehehehe.
    although we have the old idler and pitman arm na in a bag after they were replaced sa casa a couple of weeks ago (got the parts sa factory).
    Jul 2004
    Quote Originally Posted by PROMDIBOY
    PromdiBoy, How do you check damaged pitman arm and idler? Please share. Seems that my pitman arm need replacement too as I could hear a metal jerk coming from the steering cloumn on sudden stop. Maganit na ring ang steering when making a fast full turn. Are these symptoms of damaged pitman arm?
    Apr 2004
    otep, had my gen 2 done at zee's last year
    repair all the ball joints, tierod, pitman, idle arm, replace front CV joint boots and a few sway bar bushings. all in all costed me less than 5k.
    Pinaestimate ko sa Cruven kanina. Php12k ang total for the front and rear suspension.
    Malamang front suspension na lang pagawa ko sa kanila. Pero buy ako ng new 555 ball joints and KYB gas shocks. Yung ibang items na lang pagawa ko sa Cruven.
    I'll just DIY and/or get Dick for the other stuff.
    OTEP..ano yan repair lang?mukhang madugo ah....kung panay japan replacement ba eh ganun din ang presyo?
    Php12k is front and rear. Yup repair. If Japan parts, front pa lang iyang 12k.
    But siguro, mix ko na lang ang repair at replace to reach a good compromise.
HELP:  Pajero Field Master Repair Time
