Results 1 to 10 of 10
    Nov 2006
    ung lancer gl 97 ko kasi matic..,hirap siya humatak kapag pataas..,ano kaya problem nito..,hindi naman sobrang tagal pero noticable na mabagal siya compared sa ibang matic na kotse..,ano kaya prob? madumi lang kaya carburator? and may alam kau na shop na mura and safe magpalinis ng carburator? salamat ngmadami!
    daming kailangang silipin, starting from the carb and the condition of the automatic transmission.
    have you tried changing the ATF?
    Feb 2006
    try changing the ATF.
    well, lancer matic din sa kin pero 4g92 engine, i also noticed na medyo hirap kapag akyatan. hindi ko napapatignan,swabe naman sa straight eh.
    Apr 2006
    bro may carburator ba ride mo? I ask coz i have also a 97 lancer glxi a/t pero fuel injected sya. yup mahina sa akyatan, I have it check sa mitsu casa and they clean the valve body of the transmission sabay replace ATF na rin. Pina MUT test ko na rin in order to check if ok mixture ng air to gasoline. after done such things, i noticed that the torque of my ride improves. Mas maganda ipa MUT test mo muna ride mo sa Mitsu para makita kung saan and may problema. By the way, my computer box ba ride mo? if yes, pwede yan sa MUT test
    Aug 2006
    Quote Originally Posted by glb10570 View Post
    Mukhang di yata EFI yung system ng GL imo, carb pa yata..kung palinis carb maganda pumasyal sa may kamuning, sa A & M or M2M..ok service dun..
help with my lancer gl 97
