Results 1 to 10 of 45
- May 2019
- 61
January 21st, 2020 05:35 PM #1Good day po, Wala po talaga akong alam pag dating sa car parts and issue kaya dinala ko sa Honda service for leaks issues, kasi every cold start ko ng sasakyan is nagleleak nang kaonti sa may passenger side. Ngayon naayos na nila ung sa power steering pump, and nung na seal na daw lahat, saka pumutok or nag leak daw sa power steering gearbox na sinasabi.. Ngayon panibagong bayarin nanaman, bakit naman ganon? Dba dapat na oversee nila yung sa gearbox para naprevent ung pag putok dun? Mechanic po ba nila ung may mali dun? additional 22k ako ngayon para dun..
sino po kaya ang pwedeng makausap dun regarding if ung pag service nila ang mali? or sadya na talagang mahina ung part na un kaya di sila liable?
- May 2019
- 61
January 21st, 2020 05:48 PM #3
- May 2014
- 1,319
January 21st, 2020 05:57 PM #4I think hindi talaga cocover yan but rather you can try to appeal or request if pwede bawasan or may share lang sila sa repair costs for the new damaged part since may "fault" din sila. But they will not 100% shoulder it.
Parang sa suspension ng Honda... dalhin mo ang more than 5 year old Honda sa casa... lifter nila... dasal ka na pagbaba sa lifter, hindi dumapa yung suspension mo dahil usually it won't work right anymore. Uncle has gone through multiple hondas and usually ganun experience. Di naman sinasagot ng Honda casa yung suspension replacement even if sila nagdesisyon na lifter gamitin for service work. Parang ganun. Note: lifter na nakabitin gulong mo so hyper extended then pag baba, papasok ulit or mag compress.
I don't know if ganun pa din case sa Honda casa ngayon but it was like that for a while per my recollection of "yester-years".
On another note, akala ko matagal na EPS lahat ng Honda. May power steering fluid pa pala 2010 Civic?
January 21st, 2020 05:57 PM #5
- May 2019
- 61
January 21st, 2020 06:20 PM #6Actually pina diagnostic check ko xa sa oil leak which is 800 pesos, check lang. Then kinabukasan nag quote na sila ng mga gagawin, power steering pump overhaul, gaskets, seals, labor umabot ng 11k. so ayun ginawa na nila, the next day tumawag sakin, may nakita nanaman daw leak and need i-silicon which is additional 3.5k, so akala ko okay na... Kinabukas tumawag nanaman at nung inoverhaul daw nila, saka nagkaron ng tagas sa gearbox kaya pinapunta ako dun and pinasilip sakin ung bagong sira (No idea talaga sa kung ano pinagtututuro nila)... inexplain nila na after maayos and maseal ung steering pump, saka pumutok ung sa gearbox.. Kaya nagulat ako, yung kakaunting problem ko sa tagas nung una eh lumala nang lumala, kaya di ko na alam kung tama ba talaga ung nangyayari... ngayon, ung sa gearbox lang is 22k! Adding 11k+3.5k+800, almost 38k aabutin.. Pumayag naman na ako since no choice ako kasi biglang lakas ng tagas, dko na malalabas sa knla un.. Nahihirapan lang po ako tanggapin na ganun ung nangyayari..
- 54,226
January 21st, 2020 06:23 PM #7
January 21st, 2020 06:24 PM #8
January 21st, 2020 07:00 PM #9
kahit saang mechanic mo naman dalhin yan, halos labor lang magkakatalo ng malaki
only issue is sa Casa, puro bago parts na gagamitin nila.
kung sa 3rd party talyer mo yan dinala, baka palitan na nila ng buo (pero surplus) yung power steering mo.
the car is out of warranty and I guess dinala mo sya sa Honda for peace of mind.
halos lahat na sa power steering mo is napalitan... it should work good as new and I'm sure may konting warranty yung trabaho ng Honda
January 21st, 2020 07:02 PM #10
Firefox browser - :wonder: may error kapag mag attached ako ng piktyur sa computer ko insert image...
Problems with viewing Tsikot on non-Chromium...
